Angle of front speaker?
Old Mar 7, 2008 | 04:18 AM
T_K's Avatar
T_K
Default Angle of front speaker?
I haven't had the car apart to actually take a look yet, but I know many here have seen the door speaker area quite often, is there any wiggle room for a speaker using a spacer to be angled at all? Plan was to just use any basic coax speaker to replace base speaker and to drill out the rest of the dimples in the baffle. I just started wondering, if theres any room to work with between the metal and the door panel, for a speaker to be angled upwards any meaningful amount.
TK
Old Mar 7, 2008 | 05:16 AM
350zspl's Avatar
350zspl
no room for adjustment
Old Mar 7, 2008 | 03:48 PM
token5gtd's Avatar
token5gtd
TK
instead of drilling out the holes, use a dremel and cut out all of plastic with the holes and without the holes leaving only the straight pieces in the middle. then use speaker grille fabric to wrap around the cover. then exercise your sewing skills or borrow somebody else's to create a drawstring around the edge of the fabric. voila, no more plastic blocking your sound.
Old Mar 7, 2008 | 05:22 PM
crawfeesh's Avatar
crawfeesh
TK
Not sure if you meant it this way, but you might be able to angle towards you (looking directly at the speaker, move only the right side out). I was thinking of doing the this and moving the speaker up about an inch.
Old Mar 7, 2008 | 05:25 PM
Spike100's Avatar
Spike100
^^ Any concern about protection from a wayward clumsy foot damaging the speaker?
--Spike
Old Mar 7, 2008 | 06:09 PM
token5gtd's Avatar
token5gtd
--Spike
simply warn all who enter your car....as simple as telling them to knock their shoes off before they get in
Old Mar 7, 2008 | 06:30 PM
Spike100's Avatar
Spike100
^^ If it were only that easy...
--Spike
Old Mar 7, 2008 | 09:32 PM
crawfeesh's Avatar
crawfeesh
--Spike
You can leave more vertical/horizontal lines on the stock grill - that should protect the speakers.
Old Mar 8, 2008 | 02:16 AM
T_K's Avatar
T_K
This is what I was mostly thinking too. If I bought one of the 1-1.25in spacers, and cut the mounting face at slight angle, to try and aim the speakers towards the center of the car. It might not be able to angle much, but I'll take any minor improvement from the stock location.
TK
Old Mar 8, 2008 | 07:13 AM
crawfeesh's Avatar
crawfeesh
TK
Let me know how that turns out. The spacer's thickness might be the key because there's little room to play with on the speaker's left side. How are you going to cut the mounting face? I haven't though of a practical way to make a clean cut without a huge miter saw.
My speakers have been sitting here for a year and I haven't had time to install them.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
