Components Recommendation for JL 300/2
Old Mar 20, 2008 | 03:27 PM
Denver350z's Avatar
Denver350z
Default Components Recommendation for JL 300/2
I bought some JL XR-650-CSi component speakers used on the forumns here and JL 300/2 amp. The guy I bought them from ran them with the JL amp.
Anyways, I got them installed about 4-5 months ago and about a month after the install I started hearing not so good sounds, which I thought was them rattling due to a possible bad install. Well, over time they have gotten worse, and now they sound like they are blown out. I have a LP filter on them, but certain lower freq. noise makes them sound like crap.
I have never heard a blown out speaker before - does this sound like that is teh case here?
If they are blown out, what speakers would people recommend for the 300/2 amp? I really liked these components, but I dont want to chance them blowing out again if I get the same pair.
Old Mar 20, 2008 | 03:35 PM
doug's Avatar
doug
where do you have them crossed over? perhaps you are trying to play them at a frequency they are not optimal at .. you should be using a HPF on them not LPF.. i have my front stage crossed over at 100 hz
as much as i hate JL Audio Products.. i would rather you fix your current problem with having to spend extra
Old Mar 20, 2008 | 06:46 PM
Denver350z's Avatar
Denver350z
Sorry, ya HPF.
Its set at 125... if I move it down to 80 or 60, the rattling gets much worse.
Is it possible that its a mounting issue? I should take the door panel off and check it out.
Old Mar 20, 2008 | 07:32 PM
KelekonaKustoms's Avatar
KelekonaKustoms
the JL XR's only take 70 watts RMS each, the 300/2 is feeding them 150 watts RMS each. way too much power for those speakers
Old Mar 21, 2008 | 02:06 AM
StreetOC192's Avatar
StreetOC192
+1, that is if he has the gains turned more sensitive. He may have them backed off.
This rattling you speak of could very well be the infamous door panel buzz. Have you deadened the doors at all?
Here's what I would do:
* Tune the gains on the amp to get 70 watts from the output leads by following this tutorial (your target=16.7 volts) - http://www.subwoofertools.com/forum/setgain.asp
* Adjust your HPF to 100Hz
* Pull the door panel off and then play some music
Are you still hearing the rattle/buzz/hum? Can you quell this by damping the door with your hands?
Old Mar 21, 2008 | 07:39 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
simplist thing to do , is remove the speaker, hold it in your ahnd, and play it, if it still makes that horrible sound, its prolly blown...
125hz hp should not blow a speaker, unless you really really got the gains cranked...lol another benefit of kicks is increased power handling on the spekaers
whats your budget?
b
Old Mar 21, 2008 | 08:01 AM
Denver350z's Avatar
Denver350z
I will do this tomorrow afternoon to get this solved.
Thanks for your help.
Old Apr 3, 2008 | 12:08 PM
Denver350z's Avatar
Denver350z
Alright, so it turns out that my drivers are the source of the rattling, so I am going to replace them.
From purely a fitment and power handling standpoint, anyone have recommendations for component speakers?
I also am going to put in some rear speakers to fun off of my head unit for rear fill. Recommendations there would be nice as well.
Thanks for everyone's help.
Old Apr 3, 2008 | 12:32 PM
Denver350z's Avatar
Denver350z
How about the Diamond Audio S600s? It says mounting depth is 2-1/8"... and my JL XR650's have a mounting depth of 2.81 in. Should be easier to fit cause right now I have a pretty big door spacer.
For the rear, I could do the diamond D362i... but the problem is that they call for 60 watts RMS and my headunit is probably 22 watts.
Old Apr 3, 2008 | 02:18 PM
UltraYellow350z's Avatar
UltraYellow350z
16psibrick can build you a really nice set of kicks with speakers for a good price. He did mine and its amazing. I would recommending doing kicks and then you wouldn't have to worry about mounting depth.
Old Apr 3, 2008 | 03:55 PM
Denver350z's Avatar
Denver350z
I am really hesitant about doing Kicks. I think I will actually "kick" them, and I would like it to look as much like stock as possile. I have though about doing the DIY mod to the speaker grills though to help the sound quality.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
apex locator
Jul 23, 2021 02:27 AM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
