So I pick up my 04' Touring, and this is whats on the roof...
Old Apr 12, 2008 | 02:56 PM
nyguy4u's Avatar
nyguy4u
Default So I pick up my 04' Touring, and this is whats on the roof...
It's completely off-centered (it's 5 inches from the passenger door!), and it's HUGE! This is my first Nissan, so I am unsure if this is the XM antenna that came stock with the vehicle in '04. Has anyone seen this XM antenna before? I want to take it off, but it doesn't budge, so I am guessing it's not a magnetic antenna? But on the other hand, I never thought you could "hard" mount an XM antenna?
I want to get an aftermarket stereo, and I don't want this ugly box on my roof. Any suggestions on how to take this thing off? Is it magnetic? Is it bolted to the car? I don't want a damn hole in my roof if I remove this.
Thanks in advance for the help!
Old Apr 12, 2008 | 03:22 PM
Armando's Avatar
Armando
take it offffffffffffffffff
Old Apr 12, 2008 | 03:51 PM
nyguy4u's Avatar
nyguy4u
I want too, thats the problem. I don't know if it's magnetic. I pulled on this thing pretty good, and it didn't budge.
Old Apr 12, 2008 | 03:56 PM
DelayedZ's Avatar
DelayedZ
On the XM kits I've installed it's usually a magnet, however, I have seen double sided tape used.
Old Apr 12, 2008 | 03:58 PM
nyguy4u's Avatar
nyguy4u
Thanks for the reply.
have you ever seen it bolted to the car however? I'm afraid to pull harder then I was.
Old Apr 12, 2008 | 04:06 PM
SuperBlack350z's Avatar
SuperBlack350z
on my previous car, my XM was a double sided tape and a magnet. I use to use it without pulling off the tape because it stuck on well just with the magnet but if it doesn't move, the person must have used the tape as well.
Armando's Avatar
Armando
its probably taped up.
Old Apr 13, 2008 | 03:52 AM
Spike100's Avatar
Spike100
Heat the roof area and antenna base with a hairdryer, then twist to break the tape seal (easier than pulling straight up). Be careful so as not to scratch the paint.
I'm not sure why the antenna is so large.
--Spike
Old Apr 13, 2008 | 04:13 AM
GodSendsDeath's Avatar
GodSendsDeath
Heat gun like spike said it will come right off. I had one of those and hated XM lol.
Old Apr 13, 2008 | 02:59 PM
Spike100's Avatar
Spike100
Anyone following the manufacturer’s instructions when mounting an antenna for XM or Sirius satellite radio would arrive at this result (which is horrible and ugly).
You do not need to mount the antenna on the outside of the car. I would recommend mounting the antenna on top of the dash or on top of the rear strut. You can bury the antenna below plastic layers for a more stealth installation, but doing this won’t provide the best reception.
This is a picture of a Sirius satellite antenna meant for exterior mounting.
A: The antenna receiver
B: The ugly covering for the antenna wire that runs outside the car’s interior
C: The antenna wire that runs inside the car
D: The super-ugly flap designed to hide the transition from the exterior wire to its interior path
--Spike
Old Apr 13, 2008 | 07:42 PM
NoahzBurnt's Avatar
NoahzBurnt
that is the exact reason i ordered my Z w/o XM. I believe it is double sided tape. The dealer mentioned that it is a dealer installed option and they tape it on there. BUt we all know how accurate sales people in dealerships are
Old Apr 14, 2008 | 08:20 AM
seekndestroy19's Avatar
seekndestroy19
Originally Posted by nyguy4u
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHH. TAKE IT OFF!
Old Apr 14, 2008 | 08:22 AM
NickRaine78's Avatar
NickRaine78
pop that pimple!
Old Apr 14, 2008 | 05:43 PM
Spike100's Avatar
Spike100
Exactly… Like you, I never have the dealership install “dealership installed components” (well… maybe Nismo floor mats ). I don’t want a rookie messing with my car.
I have a lot more confidence in the Sponsors here on my350z.com.
--Spike
Old Apr 19, 2008 | 11:20 PM
Pete's 03SVT's Avatar
Pete's 03SVT
That is one of the original XM antennas. When XM first came into the market the antenna were HUGE, like yours. It has a magnet, but if it won't move like others say it is probably taped.
Old Apr 20, 2008 | 06:40 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Yeah, it has a magnet, but it could just be a very strong magnet. I had one of those before in the past on another car, and once it was on, it wasn't moving at all hardly.
Dsowe
Feb 17, 2021 10:38 AM
Jambo016
Sep 16, 2016 01:08 PM
