NEED HELP! My radio and Gauges will not POWER up ?!??!
Old Apr 23, 2008 | 04:11 PM
Rav3nRacing7's Avatar
Rav3nRacing7
Exclamation NEED HELP! My radio and Gauges will not POWER up ?!??!
I need HELP... ASAP PLEASE.... I UNPLUGGED MY RADIO...
http://liljerk.morpheus.net/350Z/dash_removal/
AND PLUGGED IT BACK UP... MY GAUGES ARE NOT LIGHTING UP???? MY LIGHTS ON MY AC ARE THE ONLY THING THAT LIGHT UP? WHAT DO I DO>????
I have an apline mp3 cd player single den.
PLEASE HELP
Old Apr 23, 2008 | 04:49 PM
smallello's Avatar
smallello
Are you sure this plug is all the way in?
Old Apr 23, 2008 | 05:25 PM
smallello's Avatar
smallello
Did you disconnect the battery before you started taking it apart? You could've blown a fuse for the gauges... I think it is separate from the radio.
Old Apr 23, 2008 | 05:50 PM
smallello's Avatar
smallello
Those links are dead...
Did you check any other fuses? There is a separate fuse for the gauges. I am trying to find out which one...
Old Apr 23, 2008 | 06:02 PM
smallello's Avatar
smallello
Did you check the fuses by the battery? I think it is a 10 amp fuse.
Old Apr 25, 2008 | 07:21 AM
Partyboy25's Avatar
Partyboy25
so you have checked the fuse box behind the battery with the tall black cover on it? (The sneaky one that Nissan didnt even tell me about when I had a problem with my headlights)
Old Apr 25, 2008 | 07:25 AM
SuperBlack350z's Avatar
SuperBlack350z
Originally Posted by Rav3nRacing7
i just want to tell you guys that you suck, Besides smallello which tried to help... i fixed it myself.
your attitude seems like this forum was suppose to help you or something
Old Apr 25, 2008 | 07:35 AM
Partyboy25's Avatar
Partyboy25
lol
Old Apr 25, 2008 | 07:39 AM
quentinc25's Avatar
quentinc25
Check your plugs and make sure none of the wires didn't pull loose from either end.
You suck for screwing your junk up!! Get a freaking repair manual and learn something before you come in here asking for help and then cry because you didn't get an immediate response.
Old Apr 25, 2008 | 09:14 AM
smallello's Avatar
smallello
Ok, so now you should share the fix with us...
Old Apr 25, 2008 | 10:16 AM
quentinc25's Avatar
quentinc25
To quentinc25, SuperBlack350z, wow you both are jerks...
Thanks, it gives me a lot of pride to hear that from you.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
