ARC AUDIO FD10's High end woofer need help
Old May 29, 2008 | 06:01 AM
jcrocka288's Avatar
jcrocka288
Question ARC AUDIO FD10's High end woofer need help
Just purchased some of the above subs from a member on here and he gave me a pretty good opinon on what amps to get for the subs to sound to there capible performance. i understand from many reviews from perfessionals to regular customers of these subs that they are very well designed to perfection to sound great as well as there amps most of all. Now my problem is there amps are prettty expensive when it comes to one that can put out 2 channels of around 300-500 each channel (300-500watts per sub). soooo im trying to figure out what amps i could purchase that are highly recommended for good sound quailty and not just alot of empty watts that will power these subs to hit hard an sound like actul musical bass like they should. Thanx..kinda a budget question i suppose lol..(for refrence ive found the jl HD amps and all the amps that are above 700 that have been recommended frm other brands, wondering if theres anything else worth getting thats possible cheaper that anyone may know of.) thanx again in advance
Old May 29, 2008 | 07:40 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Lots of good amps. Check out Elemental Design for a good, inexpensive amp.
Box design and installation will have a larger impact on the sound of your subs than any amp.
Old May 29, 2008 | 07:47 AM
jcrocka288's Avatar
jcrocka288
hmm wow see thats one of those things i knew about but completly over looked was the box design..what do u suggest for and under strut style box?.....not to get off topic still other to make suggestion on initial thread question as well. thanx
Old May 29, 2008 | 08:56 AM
folgrz's Avatar
folgrz
well i was looking online and saw that those subs only require 250 watts rms ...
i would get this amp if i were you
http://www.woofersetc.com/index.cfm?...roduct_ID=5478
as for box design.... the Zenclosure box will be fine
Old May 29, 2008 | 09:31 AM
BlueBoxer's Avatar
BlueBoxer
Zapco, Memphis, Audison, and USAmps are all great. Budget and preference will be the main factors. The JL HD amps look interesting, and I have been tempted to shrink my system down to a smaller footprint.
Old May 29, 2008 | 11:07 AM
jcrocka288's Avatar
jcrocka288
this is only for one sub tho is it not? you probably know more then me so thats why im asking haha. i have two of them just in case i didn't mention it above and would like to run both off one amp...thanx for the quick responses tho guys excellent help so far....as for the Enclosure this looked kind of interested what do you think..because i know this is kind of important so i dont want to get a box just for looks if its not going to sound good..the Other enclosure are basically exact same non ported just sealed this one just has the z emblem on the back what do u think worth it? like it? ..http://cgi.ebay.com/ebaymotors/350z-...spagenameZWDVW
Old May 29, 2008 | 02:49 PM
BlueBoxer's Avatar
BlueBoxer
See if this link helps, not sure if you have single or dual voice coils.
http://www.crutchfield.com/learningc...2%2Dohm%5Fmono
Old May 29, 2008 | 03:06 PM
jcrocka288's Avatar
jcrocka288
is the mono amp the best way to go, sound quality wise?
Old May 29, 2008 | 04:00 PM
jcrocka288's Avatar
jcrocka288
bump
jcrocka288's Avatar
jcrocka288
question// help bump haha
Old May 29, 2008 | 08:43 PM
djscotty's Avatar
djscotty
I have been installing Arc amps since they have started business. Exceptional Quality. Look at the Kar series, they are priced pretty reasonable. Have great sound quality and awesome performance. There 900.1 or 1000.1 would be perfect for that setup and the new design looks nice and not to flashy.
Old May 30, 2008 | 09:31 AM
jcrocka288's Avatar
jcrocka288
bump
Old May 30, 2008 | 09:35 AM
DVFlyer's Avatar
DVFlyer
Speed of White
If you buy a good quality amp, it won't matter whether it's mono or multi-channel.
How are you powering the rest of your system?
I may be selling my DLS A6 which would be an excellent amp for your subs.
Old May 30, 2008 | 09:58 AM
folgrz's Avatar
folgrz
You can wire 2 subwoofers to a mono amplifier no problem it all of how you wire it. It all depends on what final load you want to run your amplifier at (ohm) as well do you happen to know if the woofers are Dual 2 or Dual 4
I would be able to help out the situation a lot more if i knew that
here is a useful link that you can use ...... http://rockfordfosgate.com/rftech/woofer_wizard.asp
Old May 30, 2008 | 12:12 PM
jcrocka288's Avatar
jcrocka288
4 ohm i believe the subs are on there way to me from a member of this site..ill have to ask him to get a quick response then just waiting for them to come in the mail.
pr_350z
Oct 1, 2015 05:03 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
