Amp will not work...
Old May 29, 2008 | 06:35 PM
Zboostin's Avatar
Zboostin
Default Amp will not work...
I have 2 Alpine V12 MRD-M605's wired per sub and one of them will not work, the screen will just flash throwing an error code "CURR, too much current" but Ive checked EVERYTHING and it's all wired up correctly. Am I missing something here???
Old May 29, 2008 | 08:31 PM
Zboostin's Avatar
Zboostin
Bump... Anyone have any input on this???
Old May 29, 2008 | 11:38 PM
cbr900son's Avatar
cbr900son
Probably too much current. Seriously tho we have no clue how u wired everything etc to see if we see any mistakes. From that evry little bit of info only thing i coudl even guess is that u didnt put a fuse on ur power wire or something along those lines.
Old May 30, 2008 | 10:28 AM
DVFlyer's Avatar
DVFlyer
Speed of White
You have two amps per sub? Are you sure those amps can be connected in such a fashion?
Old May 30, 2008 | 10:38 AM
Crom's Avatar
Crom
4 amps for 2 subs ?... maybe I misread. anyway check the fuses on the amps themselves.
Old May 30, 2008 | 11:16 AM
Zboostin's Avatar
Zboostin
Sorry I did a typo, I meant to say that I have ONLY 2 subs one for each sub. The fuses and everything is okay. I was just hoping someone here has a similar setup or equipment that may know something that I don't.
Old May 30, 2008 | 12:05 PM
DVFlyer's Avatar
DVFlyer
Speed of White
I'm guessing you'll catch the typo in the post above while I'm replying....
Ground both amps at the same point and run them off the same power wire. See what happens after that.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
cashmoney03
Sep 27, 2015 05:24 PM
NFAC
Sep 26, 2015 10:11 PM
Shane86
Sep 17, 2015 05:33 PM
