technical ? about building a sub enclosure
Old Jul 23, 2008 | 03:44 PM
atlantavip's Avatar
atlantavip
Default technical ? about building a sub enclosure
If I have a sub enclosure that is one single chamber and I'm trying to determine the tuning frequency:
do (2) 3"(diameter) by 4.5" (length) ports equal a 6" (diameter) by 4.5" (length) port or a 3" (diameter) by 9" (length) port?
Old Jul 24, 2008 | 04:08 AM
StreetOC192's Avatar
StreetOC192
Using the basic mathematical equation to find the area of a circle [A=pi(r^2)]:
The area of ONE 3" port is 7.065"
The area of TWO 3" ports is 14.13"
The area of FOUR 3" ports is 28.26"
The area of ONE 6" port is 28.26"
So two 3" ports do not equal one 6" port in area.
Old Jul 24, 2008 | 05:31 AM
atlantavip's Avatar
atlantavip
wow... i should be ashamed... so (2) 3" ports will have the same area as roughly (1) 4.25" port
Old Jul 24, 2008 | 05:39 AM
StreetOC192
Roughly, yes.
Are your plans asking for TWO 3" ports, but you only want to use one?
Old Jul 24, 2008 | 11:57 AM
atlantavip's Avatar
atlantavip
I have an enclosure that looks similar in shape to a zenclosure... it is an mdf/fiberglass mix that stops just before the space under the rear strut bar... you can't get an idea of its shape without looking inside... I'd say the true internal volume is around 1-1.15 cubic ft (sealed)without the driver... I have a RF HX2 10 being driven by a bridged Crossfire 402 (400X1)... it sounds like a** with too much airspace being sealed for my sub... I bought (2) 3"X4.5" ports and (2) 2.75"X5.25" ports and want to see if I can get a better sound out of it before buying something else... trick is that it's only about 8" deep
Old Jul 24, 2008 | 03:05 PM
adamtaylorpcb's Avatar
adamtaylorpcb
reverse fire?
also in the mathematics you must include length in that problem
Old Jul 24, 2008 | 03:13 PM
adamtaylorpcb
the volume would be 31.79 for each of the 3"(diameter) by 4.5" (length) totaling 63.58
127.17
63.58
Old Jul 24, 2008 | 03:28 PM
atlantavip's Avatar
atlantavip
firing toward the hatch
(1) 2.75"X5.25" port @ 1 cubic ft = 47hz
(2) 2.75"X5.25" port @ 1 cubic ft = 63hz
Old Jul 25, 2008 | 07:32 AM
dryseals's Avatar
dryseals
Speaker first, tuning later. This is my first post here, I just recently bought a Z and I'm just looking around. I'm 50 and have built sound systems since I was very young. Since you already have your enclosure, figure volume first, then decide if you want sealed or ported and find your speaker from there. If you go ported, then work on the port volume you'll need. I use several programs for calcs, but I tend to stay with SoundEasy for tuning, we can even plug in the cabin volume and get you a closer look an real world before you turn the first screw.
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
