Hiss
Old Aug 9, 2008 | 06:24 AM
Roper215's Avatar
Roper215
Default Hiss
I have a lot of hiss out of my stereo...
What can be the cause of this?
It sounds like the noise is literally coming out of either my equipment (amps/eq) or my sub...
gains on amps are almost all the way down
Suggestions?
Old Aug 9, 2008 | 06:45 AM
doug's Avatar
doug
sounds like a bad ground .. or bad RCA placement
Old Aug 9, 2008 | 06:48 AM
Roper215's Avatar
Roper215
Default ?
It has done it with two different amps.
ground is sanded to the metal.
No RCA's, using Symbilink cables from Zapco. They are supposed to be balanced and noise free...
Suggestions?
Could it be noise from the power source on my EQ? I tapped the large yellow wire off the bose amp...
Old Aug 9, 2008 | 07:07 AM
doug's Avatar
doug
its really hard to troubleshooot.. and very annoying to pull down every component piece by piece to see whats exactly causing the problem.. but you just might have to do that
Old Aug 9, 2008 | 07:13 AM
Roper215's Avatar
Roper215
Default Most Likely?
The noise is high pitched and does not vary with throttle response...
The noise sometimes comes and goes but typically just comes.
What are the most likely culprite in this issue?
Could it noise in my power wire?
I feel like my grounds are solid, all rigidly mounted with ring terminals and on bare metal.
The power dist. block is a stinger with a 4 ga in and a 4 and an 8 out.
The ground wires are not more than 30 in each of the same gauage as the amp power wires.
I am using stinger or JL wire for everything.
Could it be the fact that my EQ being fed by the high level signals needs a llc and fed it a low level signal?
I just installed everything and now it appears as though I have to gut the whole system again...
Old Aug 9, 2008 | 08:49 AM
THEDUKE's Avatar
THEDUKE
Gains are to High.
Old Aug 9, 2008 | 09:22 AM
Roper215's Avatar
Roper215
Default gains?
Originally Posted by THEDUKE
Gains are to High.
gains on EQ are set to 0 and gains on amp are set to almost 0...
I have not gone through the eq 2 watt rms calibration yet though..
Old Aug 9, 2008 | 09:49 AM
Roper215's Avatar
Roper215
Default potential problem
could it be that instead of using the remote turn on at the amp i used the ignition on lead?
Just a thought... also, what is the color code for the remote turn on at the bose amp?
Also, in position 2 no hiss, engine cranked I get the hiss.
Old Aug 9, 2008 | 06:40 PM
Roper215's Avatar
Roper215
Default ...
OK, so I checked the eqx, and apparently they ship the device with the gains turned to the maximum...
I'm an idiot...
I turned the gains down to a respectable level and I no longer hear the noise... once again, I'm an idiot.
I will repost if I get the noise again... hopefully this is a dead thread...
Old Aug 10, 2008 | 05:07 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
hey i pmed you back...but i also just remembered osmeting
what are you using to convert the sginal from rca to simblink? t-f? slb-U? tp4?
b
Old Aug 10, 2008 | 05:18 PM
Roper215's Avatar
Roper215
Default ?
b
I am using the rca to symilink cable (cable they come with) with a 1 ft m2m connector.
Old Aug 10, 2008 | 11:47 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
so you are using the SLRCM.01 or the SLDIN T-F, refer to this link:
http://www.zapco.com/prod/symb_prods/symbcableFrame.htm
in either case, you are using hte regular zapco referneces right? have you tried going from the headunit to the amps via just rcas? and see if you have that same issue. give htat a shot, run a cable just outside of hte car, plug it in and see if hte hiss goes away, and let me know how it goes
b
Old Aug 11, 2008 | 05:07 AM
Roper215's Avatar
Roper215
b
I am using two of the sldin.t-f's (out of the eq) connected to a 1ft sldin.01 going into the amps.
I cannot run just rca's b/c the 500.1 only has the symilink connection.
Also I have a stock bose headunit.
I also had the same type noise when I was running different amps with just RCA's from a cleansweep unit. Amps are now grounded to a different spot in the car where the paint has been removed so it is bare metal to metal contact.
the only thing that is used from previous install is the main power wire and some of the connections out of the bose amp where I spliced in.
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Midnight350
Jan 13, 2005 12:18 PM
miken168
Jun 21, 2004 09:00 AM
350zWhite04
Jan 14, 2004 05:43 AM
JonsilvZ
Jan 13, 2004 04:51 AM
