Navigation question
Old Aug 11, 2008 | 10:41 AM
srt4turbo1's Avatar
srt4turbo1
Default Navigation question
I sat in a 2008 350z with Navigation and behind the drivers seat there was a place to load DVD's Is this only on the 08's? Or can you watch DVD's on any year as long as they have the Nav? Can you watch them while you're driving?
Old Aug 11, 2008 | 10:54 AM
coachk22's Avatar
coachk22
no, that is the nav disc, how they update the info. wont play anything. At least not from the factory. All z's with nav have same thing.
m!ke's Avatar
m!ke
I always wish i could watch a dvd instead of the road when i drive my '04. dvds are more interesting.
but seriously, what coachk said.
Old Aug 11, 2008 | 10:55 AM
SupaDoopa's Avatar
SupaDoopa
What if you mounted a camera to the front and watched what you're doing through the NAV? I am sending an e-mail to the Patent company.
Old Aug 11, 2008 | 10:56 AM
JasonZ-YA's Avatar
JasonZ-YA
You can if you mod the factory nav...
First off you need a switch box to be able to switch between nav disc to aux input. check out http://www.tvandnav2go.com/ to purchase their unit.
you need this module to tap into the factory nav screen, then from there you can connect anything you want via RCA wires....DVD player, Xbox...etc.
clicky here - https://my350z.com/forum/audio-build...avigation.html
- J
Old Aug 12, 2008 | 04:40 AM
coachk22's Avatar
coachk22
will the factory nav screen actually work as a monitor?? I was under the impression that it would not. I may be wrong???
Old Sep 8, 2008 | 07:17 AM
JasonZ-YA's Avatar
JasonZ-YA
YES! it will work as a basic LCD screen...see my thread posted above on post 6!!..
i hooked up an Xbox...you can hook up a dvd player instead, I chose Xbox because it does more...
i have seen small dvd players installed in the small rear glove box cubby behind the passenger seat next to the rear speaker......, so passenger side had the movie playing DVD player and behind the driver side was the OEM factory DVD nav disc slot player..
-j
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
