questions about ohms?
Old Sep 19, 2008 | 11:22 PM
chrisl113's Avatar
chrisl113
Default questions about ohms?
im too lazy too read through pages of info i have a headache will someone remind me of the laws of resistance? if my amp is 2 ohm stable and i buy speakers that are 2 ohm stable do i just hook them up normally and they automatically go to the lowest possible resistance? thanks!
Old Sep 19, 2008 | 11:52 PM
Spork's Avatar
Spork
Depends on the speakers inputs.
Single 4-ohm? Wire directly
Single 2-ohm? Wire directly
Dual 4-ohm? = 2-ohm or 8 ohm.
Dual 2-ohm? = 1-ohm or 4 ohm.
Old Sep 20, 2008 | 08:28 AM
chrisl113's Avatar
chrisl113
ok thanks silverstone so im confused im thinking about using the whole reference line from infinity, the sub is dual 4, so thats fine but the components are rated at 2 ohm but are then described as "true 4 ohm" with 2 ohm voice coils? wtf? heres a link http://www.infinitysystems.com/car/p...=US&Region=USA
thanks
Old Sep 20, 2008 | 08:44 AM
chrisl113's Avatar
chrisl113
oh and another thing, im pretty sure a dvc sub has 2 sets of + and - and if the amp is 2 ohm stable with one set of + and - to wire that sub at 2 ohms am i going to connect the + from the amp to one of the voice coils + and the - from the amp to the other voice coils - and then connect the remaining + and - on the sub together with wire?
Old Sep 20, 2008 | 09:39 AM
Spork's Avatar
Spork
Try this:
http://www.crutchfield.com/S-biJFTNO...rs_wiring.html
Basically, you have to wire the two voice coils to each other either in series or parallel.
Old Sep 20, 2008 | 09:48 AM
chrisl113's Avatar
chrisl113
thanks ive never seen that section and im on that site a lot. so is this setup parallel or series?http://akamaipix.crutchfield.com/ca/...4-ohm_mono.jpg
Old Sep 20, 2008 | 09:53 PM
Spork's Avatar
Spork
I do believe that's parallel.
I cold be wrong tho
It's been a while since I messed with stuff like that.
Old Sep 20, 2008 | 10:00 PM
Sean's Avatar
Sean
I really think that is series. But I am in the same boat of it being a long time.
Old Sep 20, 2008 | 10:28 PM
chrisl113's Avatar
chrisl113
thanks
anyone?
Old Sep 21, 2008 | 12:01 AM
Spork's Avatar
Spork
I was right. It's parallel.
Here's a bunch of info for you OP
http://www.termpro.com/articles/spkrz.html
Old Sep 21, 2008 | 08:27 AM
adamtaylorpcb's Avatar
adamtaylorpcb
series= they run in series, the + out of amp to + of voice coil 1, to - of VC1, to + of VC2, to - of VC2, to - of amp
if that made any sense. pretty much series runs 1 big loop where parallel are al equal connections
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
