Anyone have experience with these subs/amp.
Old Sep 23, 2008 | 07:20 AM
styles's Avatar
styles
Default Anyone have experience with these subs/amp.
Kenwood KFC-W2511 10-inch subs and/or this amp Kenwood KAC-7204? Reason I am asking because I have any experience with subs/amp. Can someone tell me if these 2 combination is compatible. And if I get most potential out of subs with that amp. Any info would be very helpful.
Old Sep 23, 2008 | 09:27 AM
350zspl's Avatar
350zspl
voice coil configuration on subs?
specs on amp?
Old Sep 23, 2008 | 05:02 PM
styles's Avatar
styles
AMP:
* 2/1-channel car amplifier
* 170 watts RMS x 2 at 4 ohms (250 watts x 2 at 2 ohms)
* 500 watts RMS x 1 bridged output at 4 ohms (4 ohm stable in bridged mode)
* Max power output 1000 WATTS x 1 @ 4 ohms Bridge
* NEW FOR 2008- BUILT IN SIGNAL SENSING TURN ON- eliminates the need to run a turn on lead (many new factory radios do not have them)
* high-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
* variable bass boost (0-18 dB at 40 Hz)
* cooling fan
* Blue illumination
* Dual Mono Drive
* MOSFET power supply
* CEA 2006 compliant
* speaker-level inputs with signal sensing turn-on
* preamp-level inputs and outputs
* fuse rating: 40A x 1
* 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
* 13-3/4"W x 2-1/4"H x 9-3/8"D
Sub:
* Sweet upgrade to any car audio system
* Kenwood woofer design features polypropylene cone with heavy duty rubber surround for deep bass throw
* Stainless steel finish adds strength and durability
* 1000 watts peak power
* Sold as a pair of woofers
* 50-300 watts RMS power range
* 30Hz-1000kHz frequency range
* 90dB sensitivity
* Stainless steel coated polypropylene woofer cone
* Oversized magnet cover keeps inner workings safe from moisture and dust
* Silver-plated push terminals
* Massive sized magnet assembly
* Reversible trim ring
* Extended pole piece
* Bumped back plate allows increased cone excursion and performance
* 6.625-inch top mount depth
copy and pasted thanks for the help
Old Sep 23, 2008 | 06:27 PM
styles's Avatar
styles
anyone?
Old Sep 24, 2008 | 04:35 AM
caly2121's Avatar
caly2121
need the specs on if its a single or dual voice coil sub and what ohm it is to find if its compatible.
found this: http://www.crutchfield.com/App/Produ...ures_and_specs
which shows that its a 4 ohm single voice coil sub and its rms power range is 50 -300 watts. and your amp is 500 watts RMS x 1 bridged output at 4 ohms (4 ohm stable in bridged mode)
so they are compatible although it may be a bit too much juice for the sub
Old Sep 24, 2008 | 07:01 AM
styles's Avatar
styles
thanks for the help I appreciate it. Also if its too much juice is there a chance I can "blow" the sub. I'm assuming "blow" mean to tear a hole?
Old Sep 24, 2008 | 08:01 AM
cbeneke's Avatar
cbeneke
My brother has had that amp or one similar to it running three 10's for quite a few years and has been very happy with it. I have no experience with those subwoofers though.
Old Sep 24, 2008 | 08:20 AM
styles's Avatar
styles
thanks
Old Sep 24, 2008 | 09:54 AM
350zspl's Avatar
350zspl
gain it down a bit
Old Sep 24, 2008 | 10:27 AM
adamtaylorpcb's Avatar
adamtaylorpcb
Originally Posted by 350zspl
gain it down a bit
416blueZ
Jun 11, 2024 10:56 AM
Workshop12
Mar 23, 2020 01:45 PM
Juztin
Nov 22, 2015 07:03 AM
dcains
Nov 11, 2015 11:36 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
