Audio Build Advice
Old Sep 25, 2008 | 01:38 PM
Ricfutures's Avatar
Ricfutures
Default Audio Build Advice
I'm getting close to pulling the trigger on getting a new audio setup and wanted to get some advice. I currently have a stock bose system and I am content with the mids and highs but the bass is absolutely terrible. So I am planning to install a new sub and head unit and keep the bose fronts and rears. I just want a fuller sound and feel that a good sub will help round out the sound inside the car much better. Not looking to wake up the neighbors with my system.
I know Sony equipment isn't favored by most here but I work for Sony and get a huge discount on car audio products. That being said will this set up work well given the specs.
Headunit: Kenwood DDX812
- Already have stock Navi and this unit is a good price with built in BT. Plan to do the mod to allow stock Nav audio.
Box: Zenclosure Type S
Total volume of airspace - 0.80ft^3
Amp: Sony XM1S
mono subwoofer amplifier
290 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
Sub: Sony 10" XSL104P5B
10" 4-ohm subwoofer
five-sided polypropylene cone with rubber surround
power range: 80-330 watts RMS (1,200 watts peak power)
sealed box volume: 0.78 cubic feet
Misc: PAC headunit adapter for Bose systems.
My questions are will this amp work well with the sub? Not sure if the watts/ohms are correct. Also, is this particular zenclosure box a good match for this sub? It appears that the sealed volume box requirement of the sub (0.78cf) barely fall under that of the box (0.80cf)
Minus the headunit I can get the box/amp/sub for under $300.
Thanks for any advice!
Old Sep 25, 2008 | 06:43 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
I suggest that you upgrade your speakers. but by judging from the specs that amp should be fine.
Old Sep 26, 2008 | 12:51 PM
Ricfutures's Avatar
Ricfutures
Awesome, really appreciate the advice. I'm sure eventually I'll get around to doing some components but for now I just need a quick, cost effective upgrade to the sound.
Thanks again.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
