help? pioneer 4000 rewire pin ?
Old Sep 27, 2008 | 10:33 AM
my06350z's Avatar
my06350z
Default help? pioneer 4000 rewire pin ?
hows it goin? i jus picked up a pioneer 4000 double din.. i got the wiring kit too. i wanted to install it so that the dvd will work when i drive.. i seen before that i got to pull a wire pin out and put it into a different spot... any help or pictures would be great... { i dont wanna do the shortcut way with pullin the ebrake one click... id rather do it this way to save me the trouble }
Old Sep 28, 2008 | 08:47 AM
my06350z's Avatar
my06350z
any1??
Old Sep 29, 2008 | 07:49 AM
my06350z's Avatar
my06350z
any help would be great!
Old Sep 29, 2008 | 10:15 AM
Spork's Avatar
Spork
DO you mean so it plays a dvd while driving?
Is there a parking brake wire? Ground it.
Old Sep 29, 2008 | 09:33 PM
BlayZ's Avatar
BlayZ
grounding it doesn't work, i forget the specifics but you have to install a toggle switch or resistor then toggle the switch on then back off after you start the vehicle, i'm assuming they changed the system so that it has to see ground, power(or whatever the opposite term for ground is) then ground again, but simply grounding the wire on the avh4000 will not work(from what i've ready in every other thread about it.... i'll be installing mine in a week or two)
Old Sep 29, 2008 | 11:54 PM
my06350z's Avatar
my06350z
yeah i heard grounding it doesnt work.. i hear you can switch one of the wires pin and it will work... anyone that knows what im talkin about please help!! waiting to install with this info...
Old Sep 30, 2008 | 11:41 PM
my06350z's Avatar
my06350z
anyone else ??
Old Oct 1, 2008 | 11:58 AM
my06350z's Avatar
my06350z
to the top....
Old Oct 1, 2008 | 12:41 PM
orgasm_donor's Avatar
orgasm_donor
Sorry to break it to you brother but the simple wire swap that is available on all AVIC series Pioneer and Premier units is not available on any of the DVD screen units. This includes your 4000.
There are two things you can do:
1) Put a toggle on your green wire. It needs a momentary negative (or ground) 'pulse' to activate the safety bypass so you have to flick it on then off to get it to work. OR you can.....
2) Buy and program a PAC TR-7 to do a single negative pulse when you turn on the screen. This is the unit that most Alpines need to work as well.
Hope this helps.
Old Oct 3, 2008 | 04:13 PM
BlayZ's Avatar
BlayZ
we use a regular relay
85 and 87 = ground.
86 = Decks Remote turn on wire.
30 = parking brake wire from deck.
from http://www.soundsolutionsaudio.com/f...howtopic=20118 supposedly a regular 2 dollar relay will work fine instead of spending 20 on the pac relay
Old Oct 3, 2008 | 04:39 PM
orgasm_donor
Well a single relay won't work unless its a timed on/off output like what the PAC piece does. I have tried a regular relay and it no worky.
Old Oct 4, 2008 | 05:59 AM
BlayZ's Avatar
BlayZ
and you've tried installing it the way they have described above? cause they've supposedly done multiple installs with that setup and had it work
jlb
Oct 15, 2017 05:10 AM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
