Kinetik HC1400 battery
Old Oct 14, 2008 | 05:52 PM
andrew16639's Avatar
andrew16639
Exclamation Kinetik HC1400 battery
Does a Kinetik HC1400 Power Cell/Battery fit in the 350Zs stock battery box.
AH:60
Amps:1500
Dimensions: 9" x 5.3" x 8.1"
Old Oct 14, 2008 | 06:12 PM
orgasm_donor's Avatar
orgasm_donor
Absolutely. I just installed the larger HC1800 today in my '03 and it fit no problem. There are other things to consider though:
1) The terminal locations are opposite so you need to flip the battery around (so you read the logo upside-down from the front).
2) I had to make a 1/0 wire extension with two large terminals coming off of the positive terminal and I also had to make new Ground wires. This is always good to do anyways. The wire coming off the the positive terminal bolts onto the factory fuse holder clamp. Its a crap design but you just have to be creative with it. Pm me for more details
3) The hold down is good enough but you'll have to loosen it almost all the way for it to work properly
4) The cowel piece that attaches to the bottom of the window may need to be ground down a bit underneath depending on what terminals you will be using.
Thats about it. Physically it will fit without issue but be prepared to do some modifying to the wiring. Good luck!
Old Oct 14, 2008 | 08:17 PM
B5I8's Avatar
B5I8
I have a HC1400 under my hood but if I had to it over again I'd go with a PowerMaster XS Power D5100R. The terminals are reversed on the 5100R so no modification would be necessary unlike the Kinetik.
http://www.powermastermotorsports.com/mobile_audio.html
They can be purchased here:
http://store.summitracing.com/partde...3&N=700+322438
Old Oct 15, 2008 | 06:50 AM
andrew16639
can you post pics.
If any one has any other battery please post pics.
Old Oct 15, 2008 | 07:30 AM
imonlykidden's Avatar
imonlykidden
Old Oct 20, 2008 | 06:45 PM
orgasm_donor
Here is my Kinetik HC-1800. Its BIG!
Old Oct 24, 2008 | 07:32 AM
orgasm_donor
Holy spam! You gonna get e-hurt a real bad!
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
OdesiTT
Sep 30, 2015 10:47 AM
Shane86
Sep 17, 2015 05:33 PM
