Avic D3 to Avic F90BT questions
Old Nov 30, 2008 | 10:26 AM
RANDY350Z's Avatar
RANDY350Z
Default Avic D3 to Avic F90BT questions
I want to sell my D3 and get an Avic F. I have the BT, USB, and Sirius. what I want to know is will the Sirius pr-n2 be compatible with the Avic f?
Are the wiring connections different---GPS Ant and handsfree mic?
Old Dec 1, 2008 | 03:30 PM
jdmteg2nv's Avatar
jdmteg2nv
GPS antenna is different, Sirius tuner should be compatible, not sure on the power harness
Old Dec 2, 2008 | 03:20 PM
geomark's Avatar
geomark
i heard the harness is backward compatible. have you checked avic411 dot com?
Old Dec 8, 2008 | 10:35 PM
RANDY350Z's Avatar
RANDY350Z
Yeah i get mixed info!
Old Dec 9, 2008 | 03:09 PM
adamtaylorpcb's Avatar
adamtaylorpcb
sirius will connect through the p-bus
the harness is different im pretty sure
Old Dec 10, 2008 | 08:59 AM
Jeff Smith's Avatar
Jeff Smith
Harness is different 100%
Old Dec 10, 2008 | 09:13 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
ditto on wiring being completely different, also make sure you get a F series with the absolute latest firmware updates, the F series have been plagued with issues from the start I think majority due to pioneer subcontracting the nav side to someone else on this model, and they hae been slowly corrected by a series of firmware updates. it will save you some headaches when using hte unit.
b
Old Dec 10, 2008 | 01:33 PM
orgasm_donor's Avatar
orgasm_donor
^^ You can also get the latest firmware update on www.pioneerelectronics.com as well as avic411. Just make sure you have a 512 meg+ SD card to use for updating.
And yes, I concur, all the wiring is different between the two decks.
Old Dec 25, 2008 | 09:13 PM
RANDY350Z's Avatar
RANDY350Z
Is it worth it?
Old Dec 26, 2008 | 05:56 PM
orgasm_donor
Originally Posted by RANDY350Z
Is it worth it?
I personally don't think so. Looking at what JVC and Kenwood both have to offer, the F90 is kind of poop.
Old Dec 26, 2008 | 10:46 PM
RANDY350Z's Avatar
RANDY350Z
Im on the fence really don't feel like disconnecting everything and having the hassel to sel it to get something to work thats already having problems. Thanks for the info I'll post agian if I do it!
kyin
Oct 15, 2015 05:54 AM
rouxeny
Audio Builds
63
Sep 27, 2009 01:56 PM
SteveZ33
May 19, 2005 08:43 AM
G35Couper
May 20, 2004 04:06 AM
ThreeFitty
Apr 12, 2004 12:45 AM
