One of the more simple SQ installs in a 350z :)
Old Dec 14, 2008 | 07:21 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
Originally Posted by LeMansZCa
i believe the kenwood camera came with a bracket to allow u adjust the angle
But did brick drill into the body to attach that or did brick make a plate of some sort to mount the camera bracket to if that makes sense?
Old Dec 14, 2008 | 09:14 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
no drilling in tihs case. not sure still what you mean, i think if you saw the camera it would make complete sense, it has a bracket, mounted to the body via double sided tape it provided, then the camera goes on to the bracket and is adjustable, the cable goes to the inside via stock grommits and then to whereever it needs to go.
b
Old Dec 15, 2008 | 02:13 AM
Chi-TownWarrior
b
The reason I asked was because, I also used the 2 sided tape, and it wore off probably due to climate changes in about 2 weeks. I have removed the camera after the fact. Thank you.
Old Dec 15, 2008 | 07:28 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
interesting, not sure, i have done a few dozen of these types of cameras, with the 3m tape they provded, non has ever fallen off. the 3m tape is what htey use to put on body kits, so its extremely strong...shouldnt ever have a problem.
m_0g
Jun 3, 2021 10:05 AM
