dc-to-dc power supply installed, causing radio noise
Old Aug 28, 2003 | 07:44 AM
etx's Avatar
etx
Default dc-to-dc power supply installed, causing radio noise
Hey everyone,
I installed my dc-to-dc power supply for my z pc last night. I grounded it to the frame of the car, and ran power from the large yellow (always on) wire on the HU harness. It works, but when I turn on the pc I get a lot of noise from the radio when i am listening to an FM station. has anyone had this problem? Is this a bad place to tap for power? mabye the power is running to close to my fm modulator? Any help would be greatly appreciated! thanks!!
ps.
I wouldn't mind tapping into the cigar lighter power, but its switched (that I can deal with) but I cannot figure out how to get behind it to solder the wires on.
Old Aug 28, 2003 | 08:06 AM
chromesilverz's Avatar
chromesilverz
It's most likely the FM modulator....This is normal.
You say you get it when you are listening to the radio (with the computer on) and NOT when it's tuned to one of the designated fm modulator channels and using your computer?
I would suggest flipping the FM modulator switch to off when you are listening to the radio stations.
Old Aug 28, 2003 | 12:18 PM
etx's Avatar
etx
yeah, I am not on the channel the modulator is on and it creates a very noticeable fuzzy noise. I just hooked up the modulator to the switched power on the hu harness. looks like its time to install a switch. I wish i didnt need a fm modulator, it sounds like ****.
loudtoyz
Apr 6, 2023 04:52 AM
wanderingstuden
Jan 28, 2016 07:03 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
codek
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
