painting my kicks... What other prep do i need to paint bondo
Old Jan 17, 2009 | 01:36 PM
adamtaylorpcb's Avatar
adamtaylorpcb
Default painting my kicks... What other prep do i need to paint bondo
im painting my kick panels soon. i glassed in some pods and bondo'd over that. sanded with 80 then 150 grit till it was smooth. any other prep i need?
i have filler primer, paint and clear already
Old Jan 17, 2009 | 07:15 PM
orgasm_donor's Avatar
orgasm_donor
Sand, sand, sand!
I would probably get down to 400 grit before applying the filler primer. Three coats paint, three coats clear and wet sand for the polished look.
Post up some pics when yer done!
Old Jan 18, 2009 | 08:15 AM
adamtaylorpcb
will do, glad you said something, i was about to lay down the filler primer after 150 grit.
should i just use 1 coat of the primer or several? someone told me to wetsand the filler primer so im lost
Old Jan 18, 2009 | 08:41 AM
adamtaylorpcb
so far this is what im working with
Old Jan 18, 2009 | 11:01 AM
orgasm_donor
Well, before you add your filler primer, try using a light coat of some flat black paint or regular grey primer to accentuate any raises or dips in the finish. Concentrate on any trouble areas first then fill, sand and repeat until its perfect. Then you can add your filler primer. I have never needed to wet sand primer - in fact, I would think that with the primer being smooth, the paint has less of a chance to stick to it. make sense?
Old Jan 18, 2009 | 11:36 AM
Spork's Avatar
Spork
Sand (and apply more filler if needed) until the surface is perfectly smooth. Each time you think it is, wipe it off with a towel and wax&grease remover. Then hold it by a light source to examine for imperfections.
Use a pretty coarse sandpaper for beginning sanding, and at least get up to 400 grit prior to primering.
After this, then use your primer-filler. Use a couple coats, wait for it to dry fully, and wetsand until it's smooth and the minor imperfections are harder to see if you let any through.
Then, apply basecoat, color coat, clear.
Old Jan 19, 2009 | 12:04 AM
adamtaylorpcb
thanks
hopefully ill be getting them finished up tomorrow
Rev_Night
Nov 7, 2020 06:00 PM
Cashwin
Oct 1, 2015 06:36 AM
