Farenheit Monitor
Old Feb 17, 2009 | 08:52 PM
surfer05rdr's Avatar
surfer05rdr
Default Farenheit Monitor
hey guys i was wondering if anyone knew of a place to pick up a farenheit monitor to install in my cubby or if anyone had one on here they were wanting to get rid of. Anyone???
Old Feb 17, 2009 | 09:16 PM
Spike100's Avatar
Spike100
The monitor you are looking for is sold under these brand names (same monitor, just a different name):
  • Farenheit T-7000MHR
  • Power Acoustik PT-700MHR
  • NESA Vision NSM-7005 7"
You can find this monitor on eBay. If you don’t like eBay, you can buy the monitor here (it's labeled as Power Acoutik):
http://www.millionbuy.com/pakpt700mhr.html
--Spike
Old Feb 19, 2009 | 08:56 AM
Goku350z2007's Avatar
Goku350z2007
don't buy the monitor from ebay, i bought mine from ebay and i think i have to get another it never turned on.
Old Feb 19, 2009 | 09:13 AM
surfer05rdr
i cant find the farenheith monitor on ebay anymore
Old Feb 19, 2009 | 10:52 AM
Goku350z2007
i bought i different model PT-718TS this one has the touch screen option.
Old Feb 19, 2009 | 02:41 PM
Spike100's Avatar
Spike100
Try searching for "Power Acoustik PT-700MHR". There are several available, and this is identical to the Farenheit model. But, the best price is from www.millionbuy.com.
--Spike
Old Feb 19, 2009 | 03:26 PM
Spike100's Avatar
Spike100
The Power Acoustik PT-718TS is the same dimensions as the Farenheit T-7000MHR and Power Acoustik PT-700MHR, so it fits the same way (space). It’s a decent NTSC/PAL composite monitor, and offers the additional feature of supporting 2 A/V inputs (the PT-700MHR has a single A/V input).
Clarification: The PT-718TS does have touch-screen function, but that feature only works with devices from Power Acoustik (for example, a Power Acoustik head unit).
--Spike
Old Feb 19, 2009 | 04:50 PM
Goku350z2007
Guys never mind what i said before, i just found out what the problem was. The monitor was not getting enough juice from the positive wire, i didn't crimp the wire the right way, i tested the monitor in straight to the battery and it worked : ).
Old Feb 19, 2009 | 04:53 PM
Goku350z2007
I bought the monitor with the touch screen option because maybe down the line there will be a need for it, you never know new things comes up all the time and it's just an extra 10 to 15 dollars.
Old Feb 19, 2009 | 05:11 PM
Spike100's Avatar
Spike100
There won’t be any “need (use) for it” unless you buy a H/U from Power Acoustik (but of course that is a possibility).
With this said, I agree with you. The PT-718TS is the newest model and doesn’t cost more, so why not buy this LCD?
I mention the fact that this monitor doesn’t support touch-screen with anything other than Power Acoustik devices so that someone doesn’t purchase this and think they now have touch-screen function. It would work with a CarPC, but that would be a foolish marriage since the Power Accoustik PT-718TS doesn’t support RGB and does not have a VGA connector.
--Spike
Old Feb 20, 2009 | 03:33 AM
Goku350z2007
The only good thing about the touch screen option is that i can switch from AV1 to AV2 right from the monitor. I will post some pictures when i'm done with my setup, i should be able to finish this weekend.
Old Feb 20, 2009 | 09:34 AM
dudegetalife's Avatar
dudegetalife
can these support navigation?
Old Feb 20, 2009 | 11:47 AM
adamtaylorpcb's Avatar
adamtaylorpcb
yes
Old Feb 20, 2009 | 12:58 PM
dudegetalife
what else would be needed for navi?
Old Feb 20, 2009 | 01:04 PM
Spike100's Avatar
Spike100
True. But here is a different approach.
My Power Acoustik PT-700MHR has only one A/V input, but I placed a rocker switch between the seats (near where the Z has its seat heater switches). I use this physical switch to toggle among three different A/V inputs. In fact using a physical switch, there is no limit on the number of A/V inputs you have with any remote monitor.
You didn’t mention this, but I believe you can also use the touch-screen functions in the Power Acoustik PT-718TS to access and change the monitor’s settings (e.g., aspect ratio, brightness, etc.). I suppose this isn’t much of an advantage (and why you don't mention it) since these are usually one time settings that are not changed after the initial setup.
--Spike
Old Feb 20, 2009 | 01:49 PM
Spike100's Avatar
Spike100
Originally Posted by adamtaylorpcb
yes
Is your expectation/desire to use the Power Acoustik PT-718TS monitor’s touch-screen function to control navigation using touch-screen, or just display the video image?
--Spike
Old Feb 20, 2009 | 03:11 PM
Goku350z2007
--Spike
i didn't play with the monitor yet, but soon after i finish with everything i will find out more about the monitor, the things i have to do this weekend is connect the rear camer my amp and the subs and i'm all set for now.
Old Feb 20, 2009 | 03:19 PM
Spike100's Avatar
Spike100
Curiosity is “killing me.”
Is your plan to display navigation on the Power Accoustik PT-718TS?
If yes, what navigation device are you using?
--Spike
Old Feb 20, 2009 | 09:50 PM
dudegetalife
thinking of doing the touchscreen version....
Old Feb 21, 2009 | 07:21 AM
Goku350z2007
Hey guys... i have pics of the touch screen monitor and works great with my Iphone.
Attached Thumbnails Farenheit Monitor-1dsc00104.jpg   Farenheit Monitor-2dsc00105.jpg   Farenheit Monitor-3dsc00106.jpg   Farenheit Monitor-4dsc00107.jpg
