Where to sound deaden..
Old Feb 28, 2009 | 06:37 PM
J350z101's Avatar
J350z101
Default Where to sound deaden..
Got 9sheet of dynomat for 100$.. not to bad a deal..So im going to try it myself..
Earlier in the month had a shop look at it and was thinking about having them deaden my car for me.. He started tapping away for the biggest rattle points.. said the Roof was the worst.. I am just thinking of doing the doors and the trunk/hatch... Will this be good enough?
Also I didnt get the roller.. As far as I am concerned I dont think it will be that hard to fnd a replacement roller*doh* but all is there anything else i should know before applying dynamat other than cleaning it with rubbing alcohol first?
Any other tips on little places where to place the mat? ; Also Should you place the dynmat behind the window track*right on the backside of the door* or the metal infront of the tracks.. or both? *Im thinking both...derr
Be gentle :}
Old Feb 28, 2009 | 06:43 PM
350Zrida's Avatar
350Zrida
https://my350z.com/forum/audio-build...uild-pics.html
Look in there.
Old Feb 28, 2009 | 06:45 PM
J350z101's Avatar
J350z101
i just got done looking at that thread before i made mine.. Lol just wanted to get an opinion just to make sure before i go all out ;p
Old Feb 28, 2009 | 06:59 PM
350Zrida's Avatar
350Zrida
I didnt do the roof. Both sides of the doors were done and the trunk. The car does not rattle. Im not sure if 9 sheets will do all that though.
Old Feb 28, 2009 | 07:28 PM
Spork's Avatar
Spork
Both doors.
Entire trunk area including the hatch.
Entire center piece.
Old Feb 28, 2009 | 07:42 PM
J350z101's Avatar
J350z101
entire center piece.... = ??
Old Feb 28, 2009 | 08:07 PM
Buckeye8084's Avatar
Buckeye8084
I would appreciate it if I can find out how much sound deadening each person used for their:
1. Doors
2. The doors and trunk
3. Any other areas you may have done
Thanks
Old Feb 28, 2009 | 08:17 PM
SuperBlack350z's Avatar
SuperBlack350z
100 sq ft
Old Feb 28, 2009 | 08:19 PM
seank426's Avatar
seank426
the people who did just the doors/trunk area, did you notice a significant decrease in road noise? Did you guys apply one or multiple layers???
Old Feb 28, 2009 | 08:32 PM
SuperBlack350z
road noise doesn't really come from my door.
how many layers depends on thickness of the material. thin ones, i would use 3 layers.
Old Feb 28, 2009 | 10:17 PM
adamtaylorpcb's Avatar
adamtaylorpcb
if you want to get rid of road noise, deaden the cubby behind the seats... you basically humping the wheel well and thats where allot of noise comes from
Old Feb 28, 2009 | 10:31 PM
quakerroatmeal's Avatar
quakerroatmeal
You'll need some sort of closed foam cell barrier in order to cut down some road noise. I highly doubt dynamatting itself would do much for road noise.
And as for where to sound deaden. The whole interior if you got enough. Roof, Doors, Floors, Hatch, everything interior.
Old Mar 2, 2009 | 10:59 AM
35oZephyR's Avatar
35oZephyR
Anyone's who's driven without the passenger seat will hear a lot road noise permeating through the cabin floor. The Dynamat type stuff (Fatmat to be exact) doesn't really work for sound coming from my hatch, but it did wonders with rattles.
I went a different route for the floor:
I placed a couple layers of cell foam Edead v.4 Teklite (from Elemental designs) and my old z mat under the passenger seat. It's noticeably quieter and I have yet to do the driver's side.
Old Mar 2, 2009 | 05:30 PM
Son of Mad Dog's Avatar
Son of Mad Dog
Was wondering this, when driving it sounds like a "window" is open behind me. Especially during rain/wet roads. This is extremely annoying.
Was thinking of doing the hatch area just to cut down on noise.
Sounds like i need to reconsider and do the hump under the cubbies.
How they could release a car that is this noisy is beyond me.
Anyone who has done this step by step have an area that cut the noise the most noticebly? Looking to do it step by step. Read a pretty awesome review that someone posted on here about the different brands. Looking into the Rammat.
Old Mar 4, 2009 | 08:40 AM
Buckeye8084
I'm in the same boat as some of you guys. I'm going to go for the challenge of doing this myself and hoping I don't totally F up my car.
Somebody said 100sq ft. Is that enough to do the rear all the way to the firewall?
This has been a good thread for me.
https://my350z.com/forum/audio-and-v...ing-doors.html
Do I just remove the 4 bolts on each corner of the door to remove it?
Thanks
Old Mar 4, 2009 | 08:42 AM
Buckeye8084
This too.
http://liljerk.morpheus.net/350Z/
Old Mar 4, 2009 | 08:51 AM
VO...'s Avatar
VO...
Administrator
That's what I did. Worked great. Others may have different opinions though...
Old Mar 4, 2009 | 08:53 AM
VO...'s Avatar
VO...
Administrator
1. Doors
Thanks
2 cans of "spray in bedliner" from Pepboys. One can for each door. 2 sheets of generic dynomatt for the trunk, plus another can of "spray in bed liner"...
Old Mar 4, 2009 | 05:02 PM
Spike100's Avatar
Spike100
If you have a coupe, you need to put sound deadening in the rear cargo floor (paying special attention to the rear wheel wells which are inside the car and allow road noise to enter the car just as you experience with a stationwagon). You can use sound deadening sheets or spray-on solutions. Spray-on-rust-proofing products applied from the outside to your rear wheel wells also reduce road noise.
You also need to add sound deadening to the pedestal behind the driver/passenger seats. Sheets or rolls of sound-deadening work best here.
Sound deadening in the doors is mostly to prevent “rattling” from the speakers since there is little road noise that enters via the Z’s doors.
A complete solution adds sound deadening to the floor under the driver and passenger seat. This would be sheets, rolls, or spray-on products.
Or… you could buy a G35/37 coupe.
--Spike
Old Mar 6, 2009 | 06:50 PM
XERMAN2001's Avatar
XERMAN2001
i used 100 sq feet in my car
