Stock Head Unit Wiring
Old Mar 21, 2009 | 01:35 PM
arron_13's Avatar
arron_13
Default Stock Head Unit Wiring
Hey guys, I've been researching a slight upgrade in my sound system. Right now I'm looking at just upgrading the door speakers and tweeters and adding an amp to give them some power. The problem is I have a non-Bose head unit, which, I believe doesn't have RCA outputs (am I right on that?). Is it still possible to wire in an amplifier? I'm not going to upgrade the head unit because I want to keep the stock appearance.
Thanks in advance for the help
Old Mar 21, 2009 | 01:42 PM
lbz's Avatar
lbz
You need a wiring harness adapter
http://www.amazon.com/Stereo-Harness.../dp/B000KL6UO4
You could run high level outputs from this to an amp but I'm not positive on the impedance on the high level outputs of the stock head unit. Search the forum for that info.
Old Mar 21, 2009 | 01:44 PM
arron_13's Avatar
arron_13
Thanks, can you run me through what its adapting? Does it just sent the speaker outputs from the headunit to the amplifier?
Old Mar 21, 2009 | 03:44 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
I'm pretty sure that is not what you need. That harness would be used if you're putting in an aftermarket HU with stock speakers.
350Z_Al
Oct 29, 2020 07:44 PM
