6 3/4"
Old May 3, 2009 | 02:37 PM
SkyMan's Avatar
SkyMan
Default 6 3/4"
Hey guys,
Wondering if 6-3/4" would fit up front in the doors without modification?
Thanks!
Old May 3, 2009 | 10:51 PM
snobird's Avatar
snobird
snobird
6 3/4 is same as 6 1/2 the 6 3/4 comes with an adapter plate which can be removed in most cases which makes it a 6 1/2
Old May 3, 2009 | 11:38 PM
Spork's Avatar
Spork
It depends...
Are the speakers a 6 1/2-6 3/4 speaker? Or strictly a 6 3/4 speaker?
Difference is... The 6 1/2-6 3/4 is basically a 6 1/2" speaker with a 6 3/4" mounting base to allow fitment in different size holes.
True 6 3/4" speakers are a little larger. Since you'll most likely be needing spacers for the front speakers, you can get a larger cutout to allow a 6 3/4" speaker to fit.
Old May 4, 2009 | 07:04 AM
adamtaylorpcb's Avatar
adamtaylorpcb
i have some for sale if you want
Old May 4, 2009 | 07:47 AM
SkyMan's Avatar
SkyMan
Thanks for the quick reply guys! I'm looking at these specifically:
http://onlinecarstereo.com/CarAudio/...roductID=17068
Old May 4, 2009 | 05:45 PM
Spike100's Avatar
Spike100
If your plan is using the stock speaker location in the front door….
I don’t think it’s so much the speaker's diameter that will be the problem, but instead the speaker’s depth.
Using the stock door mount, you can always trim a little to get a wider diameter (and I doubt you will need to do this with the speakers you mention), but you can’t expand the depth.
Question: What is the depth from wall for these speakers?
--Spike
Old May 4, 2009 | 10:00 PM
Spork's Avatar
Spork
Here ya go. Did some research for you.
It'll fit fine in a 6 1/2" hole.
2 5/8" mounting depth. IIRC, you'll need a speaker spacer. http://www.zenclosures.com/Speaker_Spacers_s/36.htm
Old May 4, 2009 | 11:06 PM
adamtaylorpcb
I have some BNIB pioneer TS-D1720C components if your interested
pm me
Old May 5, 2009 | 03:48 PM
Spike100's Avatar
Spike100
Hey Spork,
Good reply … Thanks for doing the research.
I believe SkyMan wants to use the stock door mount (Am I correct?)
If so, a 2 5/8” depth-from-wall is going to be pretty tight. The depth might be OK if the magnet (speaker base) isn’t too wide.
I’m guessing and not sure. I couldn’t fit Focals with a 2.7” depth-to-wall into the stock door space (had to go to the Focals Slims to fit).
--Spike
Old May 5, 2009 | 09:30 PM
Spork's Avatar
Spork
My MB Quart components were 2.56" deep, and I needed to use a spacer for it.
The Zenclosure spacers are a good, cheap way to fit deeper speakers in the stock location.
