amp gain/settings question
Old May 21, 2009 | 02:02 PM
seank426's Avatar
seank426
Default amp gain/settings question
Can someone please give an accurate description off what exactly the gain **** on an amp does. I hear a lot of people say its simply a volume **** where others say that that a false description.
1) If an amp puts out 600w rms and a sub takes 600w rms should the gain be maxed?
2) If the gain is at 50% is the amp only going to be able to put out 50% of its rms power?
3) What exactly does turning the gain up/down do?
Old May 21, 2009 | 05:38 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Maybe this will help?
http://www.installer.com/tech/gains.html
Old May 21, 2009 | 07:37 PM
Entaille's Avatar
Entaille
cliff notes: turn it up and down at all levels, listen to it, find what sounds best to you.
my sub hits noticeably harder as i turn the gain up.
Old May 21, 2009 | 11:01 PM
adamtaylorpcb's Avatar
adamtaylorpcb
my gains on every amp is 0 and its still more than i can take at wide open
its all about how you set everything up
the less gain the less distortion and heat
Old May 22, 2009 | 03:38 AM
StreetOC192's Avatar
StreetOC192
The best explanation that I have found helps many people.....
http://www.bcae1.com/gaincon2.htm
Old May 22, 2009 | 04:55 AM
Correct. Adjustable output. Can not exceed maximum output. Deceasing output may decrease distortion.
Old May 22, 2009 | 06:33 AM
adamtaylorpcb
with a strong signal an amp needs no gain.... thats why god made line drivers and eq's with adjustable output levels
Old May 22, 2009 | 07:37 AM
doug's Avatar
doug
the gain is to create balance over other amps and components..
turn your gains down... find the desired listening volume on your radio... then adjust each amp gain accordingly to your desired listening pleasure..
if you have an amp for your components and an amp for your sub.. depending on your type of music you listen to.. one amp may need to be higher than the other.. thats where the gain comes in
Old May 22, 2009 | 06:26 PM
DIGItonium's Avatar
DIGItonium
Gain helps compensate the low output level of your head unit. Head units that output signal greater than 2V peak typically don't need the gain set very high on your amplifier. Whatever it is, you shouldn't run your amp with gain setting maxed out. It can overheat and damage your amp even if you're not anything through it. It doesn't mean your amp will run at its full potential with maximum gain, but you are more than likely to distort the input signal to the amp. Some label it sensitivity.
The wattage is your amp's efficient load driving potential given a known load (1, 2, 4, 8 ohm). It's like the capacity of a PC power supply.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
