Quick Question On Speaker Wiring!
Old May 24, 2009 | 09:23 PM
neel6690's Avatar
neel6690
Default Quick Question On Speaker Wiring!
So I am planning on putting some new speakers in the car now, but the thing is that I dont want to place them in the stock location, I am going to have them open in the back, My question is which wires do I cut from the back of the radio? so that my stock speakers dont work anymore? thanks oh yeah and how could I amp it also? thanks
Old May 24, 2009 | 09:49 PM
genegoesfast's Avatar
genegoesfast
wow
Old May 24, 2009 | 09:58 PM
neel6690's Avatar
neel6690
wow wat u F***ing panzi? huh
Old May 24, 2009 | 11:24 PM
CaliSilvZ's Avatar
CaliSilvZ
From what i know about stereo systems, if you r going to use a stock deck you will need to use the stock speaker wires. You can always pull the wires to the new location of the speakers and connect it that way. And this of course is not using an Amp. I would search around first to see the different ways people have did their builds.
Hope this helps.
Old May 25, 2009 | 06:04 AM
CancerJCCz's Avatar
CancerJCCz
Most noobish old member of the year award...
Old May 25, 2009 | 06:23 AM
JEKL's Avatar
JEKL
Originally Posted by genegoesfast
wow
LOL.
Last edited by JEKL; May 25, 2009 at 11:41 AM. Reason: Just noticed the OP was a douchebag...
Old May 25, 2009 | 10:14 AM
Spork's Avatar
Spork
With this kind of response, I won't help.
Old May 25, 2009 | 10:19 AM
quiksilver38's Avatar
quiksilver38
wait why do you want to cut any speaker wires in the first place i thought u just want to replace the speakers...? while your back their and if your putting in an aftermarket deck, which hopefully is the case, i would definately run a nice thick ground wire straight to the frame from the H\U. when i put an indash in my 350z it wasn't getting enough juice to run on the stock ground
Old May 25, 2009 | 10:22 AM
doug's Avatar
doug
cut the red, pink and blue wires
Old May 25, 2009 | 10:29 AM
quiksilver38
what do you mean cut the blue wire!? Their ALL BLUE WIRES!!!!
Old May 25, 2009 | 04:53 PM
Spike100's Avatar
Spike100
Which speakers (front or rears, or all four) do you want to disable?
--Spike
Old May 25, 2009 | 05:06 PM
orgasm_donor's Avatar
orgasm_donor
Bose or no Bose?
Old May 25, 2009 | 05:49 PM
neel6690's Avatar
neel6690
i have a aftermarket pioneer
Old May 25, 2009 | 06:20 PM
Spike100's Avatar
Spike100
^^ OK... Send an email message to Pioneer support asking this question (How do you connect OEM wiring to the Pioneer model H/U you have).
Easy solution...
--Spike
Old May 25, 2009 | 06:40 PM
orgasm_donor
Behind the deck you can either cut the grey and grey/black and white with white/black OR if it has been hooked up via RCA (Bose low level input) then disconnect the RCAs labelled 'front'. This will disable the front speakers.
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
nanotech
Oct 2, 2015 05:02 AM
