Need help asap!!!
Old Jun 12, 2009 | 04:21 PM
350ezy's Avatar
350ezy
Default Need help asap!!!
so I was installing a after market head unit and everything worked fine and I was finishing the install and every thing stopped working. Checked the fuses and my wiring and even put the stock one back in and it didn't work. I also noticed that the gauges don't light up and my tps light came on.
Old Jun 12, 2009 | 08:44 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Did you disconnect the battery when you were installing? If not, you should have. Check your fuses.
Old Jun 12, 2009 | 08:45 PM
Spike100's Avatar
Spike100
Did you disconnect the battery while doing the installation?
--Spike
_______________________
EDIT: Wow! Same comment within a minute. That might mean something.
etkms
Jun 19, 2022 06:30 PM
LunchBox20
Oct 20, 2015 10:22 PM
