Grounding questions
Old Jul 7, 2009 | 04:20 AM
ag0240's Avatar
ag0240
Default Grounding questions
i have a avic 90 bt and i have been reading that some guys grounds the 3 grounds to the same bolt, and others say ground it to three diffrent bolts. would it make a difference if i grounded all three grounds to the same bolt? id rather do it that way.
Old Jul 7, 2009 | 05:11 AM
StreetOC192's Avatar
StreetOC192
As long as that 1 bolt is a good ground, it makes no difference.
Old Jul 7, 2009 | 05:25 AM
CancerJCCz's Avatar
CancerJCCz
And by "good ground" it just needs to be clean from paint or other contaminants and nice and tight. You can take a razor blade and scratch the area around the bolt to ensure a good connection but generally behind the dash it will be fine as is.
Old Jul 7, 2009 | 05:39 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
There's a factory grounding point behind the triple gauge that is used for many of the dash instruments. The best ground would run all the way back to the battery itself.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
