Need antenna!!!!!
Old Jul 20, 2009 | 07:13 AM
ryanfleming76's Avatar
ryanfleming76
Default Need antenna!!!!!
When I bought car the antenna had been shaved and i need to know what i would need to do to get an antenna back and where could i put a new one to get it to look good???? Hope someone can help!
Thanks
Old Jul 20, 2009 | 07:17 AM
JasonZ-YA's Avatar
JasonZ-YA
Well if the antenna is shaved? are you planning on removing the body work and reinstalling?
If not search on the interior side of the car where the oem antenna used to be, remove the plastic interior paneling and you could:
1. Reconnect a larger universal antenna and mount it under the plastic, odds are it would work (pick up reception still) in the hatch area under plastic panels....and you can stay with the shaved look?
2. See the body filler and work done in that area and from the inside out a good body shop can locate and remove the body "shave" work and then i figure you can go to a dealership and get the base, or you can go to a local junk yard and pull the base and reinstall back to stock.
if you do #2, then you can go with any antenna....link below is what typical Z owners do...
See here: https://my350z.com/forum/7248227-post5.html
-J
Old Jul 21, 2009 | 07:25 AM
cruz106's Avatar
cruz106
Default antenna
I just installed the antenna from the 08 Avenger...
I have a Kenwood HU...I seem to have improved my reception and the fit is good. Just under $9
Old Jul 21, 2009 | 07:58 AM
StreetOC192's Avatar
StreetOC192
Maybe get something like this and install it under the plastic cover on the rear strut bar. For $25, it's worth a try.....
http://www.amazon.com/Metra-44UA20-U.../dp/B000B9E3QM
Old Jul 21, 2009 | 11:34 AM
JasonZ-YA's Avatar
JasonZ-YA
^ bingo, thats like what i was thinking........didnt realize they had hideways out there.....cool..
yeah, i wouldn't want to mess with removing the body filler and paint done on the shave job..........if its clean, i would leave it alone..
-J
reno56
Interior
17
Nov 20, 2015 05:21 PM
bcoffee20
Nov 19, 2015 06:39 PM
cashmoney03
Sep 27, 2015 05:24 PM
shagz
Nov 5, 2002 04:38 AM
