WTF? Shop says Diamond Audio S600s won't fit...
Old Oct 3, 2003 | 09:42 AM
Jason's Avatar
Jason
Default WTF? Shop says Diamond Audio S600s won't fit...
Okay, so I dropped my car off at the stereo shop yesterday. I'm paying these guys a LOT of money to do a high quality custom install of my new system.
They call me this morning and say, "Yeah, we need to put 5-1/4s in your door 6-1/2s won't fit." I tell them there is no way I'm downsizing to 5-1/4", and to talk to the installer again. Have you tried using spacers??
Anyways, I've seen S600s speakers installed in other Zs here on the board. Nobody else has run into this issue with spacers have they? I think these guys are smoking crack.
Old Oct 3, 2003 | 09:46 AM
zand02max's Avatar
zand02max
SPACERS is all I can say, GL.
Old Oct 3, 2003 | 10:36 AM
toykilla's Avatar
toykilla
they are being lazy.. if they are doing "custom" install of which you speak (highly doubtful) .. they would simply fabricate some spacers... i did for mine by using the factory speakers....takes a total of 5 minutes
the problem lies in the window clearance... nissan designed the window to slide down **just** behind the factory speakers so anything deeper requires spacers.. but not too much or you bump the inside of the door cover
Old Oct 3, 2003 | 11:05 AM
Jason's Avatar
Jason
Well, the install is "custom" - like the amp rack is being produced on a CNC machine (I can't wait to see it.)
I just don't know WHAT they are thinking about the speakers. It's doubtful they are being lazy, more likely that they are busier with some dotcom guys Ferrari, or some Seahawks players H2 (this place is high end.)
Old Oct 3, 2003 | 11:06 AM
Jason's Avatar
Jason
BTW, did you do this with Dimaond Audios, or something else?
Old Oct 3, 2003 | 11:11 AM
peptidbond's Avatar
peptidbond
Does not matter. If you use 6.5", you have to use a spacer almost guaranteed. Look at the stock door speaker when you have the chance. It is molded into a plastic spacer that is at least 1/2" thick.
Old Oct 3, 2003 | 12:33 PM
ganz's Avatar
ganz
Default Spacers Can Be Made
I bought my s600s from user KJ-350. He provided a set of custom spacers. They are basically a couple of 3/4" thick fiberboard cut to the shape of the stock speaker basket. PM him if you need details.
Old Oct 3, 2003 | 01:02 PM
jtree007's Avatar
jtree007
Charter Member #53
6.5" is the right size for all the speakers in the car. You don't even have to make spacers if you don't mind destroying the stock speakers. If you don't want to do that, they can make a custom one out of MDF, depending on how deep the speakers are they will need to use two 1/2" MDF boards together as the spacer or if the speaker is not that deep, then jsut a 3/4 boad will be plenty.
I would question their abilities if they could not figure that out on their own... This is not something that is uncommon, nor is it anything dificult.
Don't be dazzaled by a place that looks High End... What is improtant is how stkilled the installers are and how well they will take care of your car.
Old Oct 3, 2003 | 01:23 PM
Jason's Avatar
Jason
Right, I've made my own spacers in previous vehicles.
Anyways, I guess they were using a pre-made 1/2 spacer; apparently MDF is below them
Anyways, they went ahead and made some 1" spacers, and everything is good now.
Old Oct 4, 2003 | 02:04 PM
Rahtok's Avatar
Rahtok
lol. I saw your car this morning, Jason. I just had a 20 gig Keg installed in the wife's new Sienna, and they did some custom fab work to get the remote display mounted. They're trying to talk me into doing a 7998 + a W7 somewhere. You're doing JL amps too, yeah?
Old Oct 5, 2003 | 08:45 AM
jtree007's Avatar
jtree007
Charter Member #53
That is my basic set up... I love my 7998 and my w7
Old Oct 6, 2003 | 07:34 PM
Jason's Avatar
Jason
Yup. I have a 300/2 now and the setup is designed to accomidate as many more layers of JL amps as I can fit. a 500/1 is next
Here is where the system stands today:
1. The shop ran out of S600s speakers, and installed S600a, now I have to take it back for a swap. Warning S600a speakers are BRIGHT.
2. The shop ran out of the 6.5" speakers I was going to put in the rear, so they put in 5.25", and I have to take it back for a swap.
3. Against our agreement, it appears that the shop did NOT run new cable into the doors, and installed the crossovers in the doors instead of in the rear where we agreed.
That said...
4. The new amp mount is pretty cool.
5. The new tweeter covers are cool too.
I'll post pics of the amp install in a second.
Old Oct 6, 2003 | 07:37 PM
Jason's Avatar
Jason
Here is the amp. It's a custom metal mount that attaches to all stock bolt holes in the compartment.
There are risers on all corners (hard to see in the pic), to attach another amp "layer" with the 500/1 later.
Attached Thumbnails WTF?  Shop says Diamond Audio S600s won't fit...-img_0063.jpg
Old Oct 6, 2003 | 07:39 PM
Jason's Avatar
Jason
Power distrobution block and fuse, mounted on the inside wall.
Attached Thumbnails WTF?  Shop says Diamond Audio S600s won't fit...-img_0064.jpg
Old Oct 6, 2003 | 07:47 PM
Jason's Avatar
Jason
New tweeter covers...
Attached Thumbnails WTF?  Shop says Diamond Audio S600s won't fit...-img_0072.jpg
Old Oct 6, 2003 | 07:48 PM
Jason's Avatar
Jason
The headunit (actually had this for a while now)...
Attached Thumbnails WTF?  Shop says Diamond Audio S600s won't fit...-img_0073.jpg
Old Oct 6, 2003 | 07:50 PM
Jason's Avatar
Jason
Okay, this is what pisses me off.
There was to be NO CUTTING OF WIRES. Everything stock was supposed to stay in place. An new cable was supposed to be run into the doors. They'll be hearing about this...
Attached Thumbnails WTF?  Shop says Diamond Audio S600s won't fit...-img_0078.jpg
Rev_Night
Nov 7, 2020 06:00 PM
sherm
Apr 11, 2020 05:21 PM
ablaine
Nov 29, 2016 10:13 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
