cheap solution for z PC perhaps?
Old Oct 4, 2003 | 08:07 AM
MY350Z.COM's Avatar
Default cheap solution for z PC perhaps?
http://www.softwareandstuff.com/dsk_...igx100700.html
Old Oct 4, 2003 | 09:23 AM
Wedge's Avatar
Wedge
Good find.........only drawback is that it doesn't have a DVD drive.....too bad, cause it could have played movies using windows media with a dvd drive...
Old Oct 4, 2003 | 09:27 AM
ASmith's Avatar
ASmith
You could just attatch a DVD drive to the usb port.
Old Oct 4, 2003 | 02:56 PM
alphared's Avatar
alphared
yep, not bad. but you would have to put in about 200-300 more to upgrade the harddrive, ram and add a DVD drive. not bad for 300-400. But I think its bit bigger that most (maybe) Don't think the the motherboard is a mini-itx since none of those have a floppy drive adapter.
Old Oct 5, 2003 | 07:10 AM
jesseenglish's Avatar
jesseenglish
Plus, unless you want to put a DC-AC inverter in your car, you've got to install a DC-DC power supply. Still a great find and I'm considering doing it even with the extra stuff you gotta get. I just wish I could find out how much power that thing needs.
Old Oct 5, 2003 | 09:30 AM
ares's Avatar
ares
Veteran
eh I built the guts of my PC for about that much. much higher quality, tho that does look a bit nicer. how many people will be able to run doom 3 smoothly in their car.
Old Oct 5, 2003 | 04:38 PM
Dissident's Avatar
Dissident
hmm.. wonder if it would fit in the mailslot behind the seat
Old Oct 5, 2003 | 07:00 PM
alphared's Avatar
alphared
nah ares, your system cost more that 100 bux, your motherboard alone must have cost about that much or more (I know mine motherboard cost more than 99 bux).
I think a regular 60W dc-dc power suppy should be more than enough to run it. uses a VIA C3 700 chip, so very low power consumtion. or use an inverter.
doubt it will fit in the mailslot area, the case is way too big for that area (I know cause my system is in that area)
Uriyo_
Sep 8, 2021 08:46 AM
Justin100
Nov 29, 2015 03:58 PM
