Rear Back Up camera install help???
Old Sep 22, 2009 | 09:50 PM
NizzmoJoe's Avatar
NizzmoJoe
Default Rear Back Up camera install help???
Ok guys, somebody has had to have installed one of these already. Ive looked all through the back of the car and have to be missing something obvious. I have my camera mounted just above the license plate and I cant find anywhere to run the wiring inside the car from the rear. Ive taken out the license plate lights thinking I could go through there but apparently it is double walled inside that space and theres no way to get a drill bit inside there to make me a nice hole. Has anybody done this and if so where did you run your wiring through?
Old Sep 22, 2009 | 10:00 PM
LVZ053's Avatar
LVZ053
I ran mine behind the license plate. there is a little rubber stopper you can remove and run the wire through. No drilling required.
Old Sep 22, 2009 | 10:09 PM
NizzmoJoe's Avatar
NizzmoJoe
WHAT!!! You mean I have been searching around the back of the car for two hours and all I had to do was remove the license plate???? Geezzzzz......9 years of car audio installs and I'm still dumb.......
Old Sep 22, 2009 | 10:12 PM
TheFarmer's Avatar
TheFarmer
lol
Old Sep 22, 2009 | 10:17 PM
NizzmoJoe's Avatar
NizzmoJoe
Thank you, it worked out great!!! I knew I was overlooking the obvious somehow.
Old Sep 23, 2009 | 05:53 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
For the next guy. The inside plastic liner has been removed and you're looking at the center of the trunk rear. The foil is "fat mat" like sound deadener.
Old Sep 23, 2009 | 06:08 AM
LVZ053's Avatar
LVZ053
Juztin
Nov 22, 2015 07:03 AM
seagrasser
Oct 11, 2015 03:27 PM
Suffolk350z
Sep 13, 2015 02:43 PM
