IDQ10 quality for ~$200?
Old Oct 6, 2009 | 12:56 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Default IDQ10 quality for ~$200?
Looking for a 10" sub for around $200, wouldn't like to go more then $220 at the most if possible. Looking for 100% SQ, not concerned with SPL AT ALL.I always hear great things about IDQ10's so I'm looking for something similar to that. Will be putting around 600w to it and will need to perform well in a smaller enclosure ~.7sqft. Thanks for any input.
Sean
Old Oct 6, 2009 | 02:19 PM
Guilty1s's Avatar
Guilty1s
Sean
Type R... one of the best bangs...errm... boom... for your buck.
Old Oct 6, 2009 | 03:39 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
I thought type r's were more for SPL/hitting really hard. I'm really looking for a high SQ sub.
Old Oct 6, 2009 | 04:46 PM
doug's Avatar
doug
the IDQ is a much better buy than the Type R
but the best sub for the price is https://ssl.perfora.net/www.ficaraud...iew.shopscript
will even blow away the high priced JLw7
Old Oct 6, 2009 | 04:51 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
I was looking at those but then again if your comparing it to a w7 isn't that a sub for SPL and not SQ. I reason I'm looking I really want an SQ sub is that I will have 2 10" which will give me more then enough SPL then I need. I just need 10"s that will fit in a Zenclosure box. The IDQ's don't.
Old Oct 6, 2009 | 05:06 PM
Mike Wazowski's Avatar
Mike Wazowski
RE Audio SEX 10's
SEX SERIES
Product Dimension
10"
Mounting Depth - 6.4"
Mounting Hole Diameter - 9.3"
Overall Diameter - 11"
Bolt Hole Circle - 10.1"
Motor Width - 7.3"
Motor Depth - 3.4"
Basket Depth - 2.94"
Displacement - 0.14 cu. ft.
Weight - 21 lbs.
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 4.4
Total Speaker Q Value -Qts: 0.42
Free Air Resonance -Fs: 26.6 Hz
Equivalent Compliance -Vas: 31 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 83.2 dB SPL
Effective Piston Area -Sd: 310 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
Sealed (compact) 0.4 (ideal) 0.65
Old Oct 6, 2009 | 05:22 PM
doug's Avatar
doug
the FiQ is an SQ Sub.. their BL and BTL are SPL Subs
Old Oct 6, 2009 | 05:48 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
who sells the RE's?
I find places selling the 12" SEX but none selling the 10"
Old Oct 6, 2009 | 06:28 PM
doug's Avatar
doug
RE is RE.. Resonant Engineering.. i have 2 RE SE 10" in my car right now..
Fi is also made by ex RE Employees
Old Oct 6, 2009 | 07:15 PM
Mikes35Oz's Avatar
Mikes35Oz
im a huge fan of JL AUDIO's 10W3's though around that RMS is a bit much for those subs... maybe a 10W6??
Old Oct 6, 2009 | 08:27 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Is #6 talking about the SE or SEx or are those the same thing? I'm a bit confused
What is the rms/max rating for this sub as well?
Old Oct 7, 2009 | 05:20 AM
StreetOC192's Avatar
StreetOC192
If pure SQ is what you are after, I would really recommend the Tymphany LAT, but I know most people are afraid to step out of the box.
So keeping it more traditional, why not go for a real SQ sub, like a Seas L26ROY?
http://madisound.com/catalog/product...oducts_id=8535
"0.6 cubic foot sealed, F3 in the lower 20's depending on amount of cabin gain"
Old Oct 7, 2009 | 01:36 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
The Seas L26ROY only talk 250wrms, I was planning on putting around 600w to it.
Old Oct 7, 2009 | 01:46 PM
redlude97's Avatar
redlude97
ED 11ov.2
Old Oct 7, 2009 | 01:51 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Has anyone heard both the IDv3 AND IDQv3.
What exactly are the differences, sound wise?
On IDs website I read 2 different things, one place says 250wrms another days 350wrms and wooferetc says 400wrms?
Whats the cheapest online store that sells the IDQ10D4v3?
Old Oct 8, 2009 | 03:58 AM
StreetOC192
In post #5, you had said you will use 2 subs, I understood that to mean you were putting a total of 600 watts mono to the subs combined. So you are going to have 2 subs with 600 watts rms EACH? There aren't going to be a lot of PURE SQ choices out there that can handle that kind of power. Most PURE SQ subs out there are rated to handle less than 300 watts rms.
I may have missed it if you mentioned it, but what amp(s) are you powering the sub(s) with?
Old Oct 10, 2009 | 06:29 AM
doug's Avatar
doug
FAIL
350Z_Al
Oct 29, 2020 07:44 PM
Twenty4
Jan 17, 2016 01:20 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
