Help Indash Boss Bv9555
Old Oct 7, 2009 | 01:28 PM
DeUceZ's Avatar
DeUceZ
Default Help Indash Boss Bv9555
Well i went to Auto Xtremes today to get my Boss bv9555 7'' touch screen double din dvd head unit installed, and the headunit it self did not line up with the bracets inside the dash so if anyone has had this problem before or has any suggestions it would be greatly appreciated. Thinking about returning headunit and purchashing another and would also like to know if any of you have preferences. not looking to spend over $450 on a dvd head unit thanks.
Old Oct 7, 2009 | 06:44 PM
Roper215's Avatar
Roper215
Default Headunit
Pioneer 4100 DVD is like 450 - 475 from Sonic Electronix and/or Woofersetc.com
better than a Boss, good reviews, preamp out's and better quality.
spend the extra 25 bucks...
Old Oct 7, 2009 | 07:21 PM
DeUceZ's Avatar
DeUceZ
Looking into it thanks.
Old Oct 7, 2009 | 07:22 PM
T-Stan's Avatar
T-Stan
ive heard the boss units are no good. pioneer's on the other hand have a good reputation. is say return it
Old Oct 8, 2009 | 04:39 AM
StreetOC192's Avatar
StreetOC192
OP, if you are saying in your first post that the headunit sits out too far from the center stack when using the factory brackets, you will have that issue with any aftermarket headunit. You or your installer will need to elongate the factory holes (or drill new holes) for the headunit to sit flush.
Old Oct 8, 2009 | 11:51 AM
DeUceZ's Avatar
DeUceZ
Ya thats what i was thinking, i also threw a cel light anyone know what it could be. Advanced said it was high input n low input on engine temp guage n something else i dont remember..
Old Oct 18, 2009 | 06:05 PM
DeUceZ's Avatar
DeUceZ
Installer had messed up on the stock brackets he had the headunit as far forward as it could go like a tool. so i took the headunit out which i was actually not pleased with and returned it.. Now trying to decided what to buy.
Old Oct 18, 2009 | 08:12 PM
350ZToeRing's Avatar
350ZToeRing
It should have either said high or low not both. But I think that code is referring to the input from the coolant temp sensor. The sensor may be bad. That or the only other thing close to that code may have been that it said "engine temp is below thermostat regulating temp" which would likely mean that your thermostat is stuck open. Thats my two cents...GL.
greenbandit21
Oct 14, 2004 12:25 PM
ss350
Feb 27, 2004 12:50 AM
ss350
Jan 3, 2004 06:24 PM
dmcgibbo
Dec 3, 2002 10:48 PM
