Illumination Wire Question...
if someone on the forum knew i wouldn't have to....
edit: If no answer comes by the end of the week I'll open it up and check for myself.
Take apart your dash and check for me then
edit: oops, just checked the sticky. I will assume its a 12V for now.
https://my350z.com/forum/2112032-post1.html
If I remember correctly from my install, it is a +12. But while you are installing your new headunit you can just confirm it to make sure. Even if someone here said the knew 100% that it was +12v, I would still double check for myself, as should everyone else.
according to the '03 service manual the base radio has an illumination input (red/yellow, pin 7) and a lighting switch input (red/blue, pin 8) that both show 12vdc when the lights are on and both show near ground when the lights are off.
As StreetOC said make sure you verify with a meter before making any connections.
350Z_Al
Oct 29, 2020 07:44 PM
Beater350z
Sep 9, 2015 03:36 PM
