05 Z Audio Install Help
Old Dec 11, 2009 | 04:36 PM
lil_shaun's Avatar
lil_shaun
Default 05 Z Audio Install Help
Hey guys, Im installing an Alpine cd9855 headunit into the Z. Im using the wiring harness that was on the Z (aftermarket, was hooked up to a Kenwood DNX 5140 previously). The harness from the Z has two wires im concerned about. There is a blue/white wire that says "amp turn-on 12v"....im not sure what to connect this to.
The weird thing is that on the headunit harness theres also a remote amp turn-on wire, which from what i know is the wire that needs to hook up to the amp (which I will do)...its just the blue/white wire from the Z harness thats throwing me off...should i just tape it closed and not connect it to anything?
The other thing is the Z harness has a dimmer ground wire (orange/black). Im just guessing this just gets grounded since theres no such wire on the cd player harness.
Any help is appreciated
Old Dec 11, 2009 | 05:02 PM
Photos and simple diagrams are always helpful.
Old Dec 11, 2009 | 06:36 PM
sdZ33's Avatar
sdZ33
The White and Blue wire from the stock harness is for the stock "amp"...
The Cd player should have a dimmer wire which you connect to the stock harness and that will dim the display on the cd player when you turn your headlights on... I seen some threads on here that people were having trouble with that wire... Make sure you check the polarity of both wires and that they can work together... I just didn't even connect it when i did my install(niether did i connect the remote wire from the stock harness)... I just capped them off and called it a day... I hoped this helped.. GL
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
