OEM amp with navigation
Old Dec 28, 2009 | 08:36 PM
customkeegan's Avatar
customkeegan
Default OEM amp with navigation
i bought an 03 350z and it has an aftermarket sub and amp. there are wires running all over the place in the car. i like things stock.
is there an easy way that i can hook up the factory amp?
where is it (they located)?
thank you.
Old Dec 29, 2009 | 12:40 PM
Spike100's Avatar
Spike100
You may not have a factory amp.
If your car is equipped with an OEM Clarion setup, you don't have an external factory amp. If your car has the OEM Bose setup, you have an external Bose amp that you never want to use.
If you have an aftermarket external amp, that's probably what you want to use since it's probably designed for your aftermarket SubW.
--Spike
Old Dec 29, 2009 | 08:59 PM
customkeegan
i do have the bose system with navigation. is the factory amp not all that great? why dont i want to use it?
thanks.
Old Dec 30, 2009 | 03:57 PM
Spike100's Avatar
Spike100
thanks.
Read this thread for more information:
https://my350z.com/forum/audio-and-v...placement.html
If you have the OEM Bose system, and you are happy with this, don’t change anything. By this I mean you should not, for example, replace the stock Bose SubW amp with a different amp and leave the Bose SubW speaker in place.
The OEM Bose setup is a tightly integrated system that is proprietary. It’s difficult to replace any part of this setup with aftermarket components and get a reliable result. If you replace any part of the OEM Bose system in the Z, you should replace all of it.
The exception (and this is arguable) is replacing the H/U. But, doing this requires a PAC adapter and the new setup might leave you with annoying speaker “pops,” and you still have the low quality Bose amp and Bose speakers.
I hope this is helpful,
--Spike
Old Dec 31, 2009 | 11:56 AM
customkeegan
thanks spike100. that was just what i was looking to hear. i will leave it as is. thanks again.
350z82
Oct 1, 2015 06:25 PM
Tochigi_236
Sep 27, 2015 03:40 PM
