Engine noise after installing new HU
Old Jan 26, 2010 | 09:34 PM
joec651's Avatar
joec651
Default Engine noise after installing new HU
I have 03 touring with the Bose system (no nav) and I replaced the HU with an eclipse cd5030 and left everything else as is. I used the wiring harness that has the RCAs on it. My problem is that now at low volumes Im getting some kind of interference that is like a whining noise that gets louder as the rpm increases. I grounded the HU on the ground wire that was on the wiring harness I bought. Is that ground my problem? If so where is a good place to ground it to back there? Thanks for any help
Old Jan 26, 2010 | 09:36 PM
joec651's Avatar
joec651
Oh and i don't know if this matters but I grounded the factory amp to the same wire
Old Jan 26, 2010 | 10:14 PM
hellsoldiers08's Avatar
hellsoldiers08
I have the same thing,but i got it done at a car audio store(custom sounds). They said they know hat the problem. When i go and get it fixed ill ask what was causing it and ill relay it to you if you still having the problem.
Old Jan 28, 2010 | 05:08 PM
carbon z's Avatar
carbon z
The aftermarket radio ground on my 03 z bose does't go through the harness ground. I have a ring terminal on the black radio ground going to the metal radio mount frame, lower left mount screw. I am running 3 external amps with no dirty noise whatever.
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
