OEM Bose Sub Problem
Old Feb 19, 2010 | 02:30 PM
rubix_cube12's Avatar
rubix_cube12
Default OEM Bose Sub Problem
hey, i was wondering if anyone new whats up with my sub. my oem subwoofer would just stop working when im driving and once i hit the plastic right where the amp is mounted, it starts working again and then cuts out once again. is it shorting out with a bad connection or is this a common problem with the 04 z?
im thinking about getting an aftermarket sub with whole new wiring to see if it might fix the problem.
Old Feb 19, 2010 | 03:17 PM
sdZ33's Avatar
sdZ33
Search the audio forum... Bose Sux!
Old Feb 19, 2010 | 03:36 PM
duro78's Avatar
duro78
pull it out and dump it...spend the coin on a upgrade
Old Feb 19, 2010 | 06:57 PM
Spike100's Avatar
Spike100
No… What you describe is not a common problem.
Risking sounding foolish… It’s probably a loose connection or bad ground.
The fix should be relatively simple. Check/refasten your wiring.
--Spike
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
