Going Active question
Old Mar 8, 2010 | 10:54 AM
Chi-TownWarrior's Avatar
Chi-TownWarrior
Default Going Active question
Ok I'm changing my sound system around, and I've decided to go active. I plan on keeping my mids from my Focal 165KPS(UV), but I cannot find the power specs on them. Would I be safe just running the current amp power (85x2)?
Second I plan on changing out the tweets for silk dome. First I want to try moving them from the sail panels to the pillars, to see if that kills the harshness, but I can't find the specs on the tweets either.
Does anyone by chance know what kind of power I can run to these for an active setup? The system can do 80 rms/160 peak. I have searched everywhere and can't find a thing.
Thanks.
Old Mar 8, 2010 | 11:13 AM
davidc81's Avatar
davidc81
i was running a set of focal 165k active on a 100wx4 rms phoenix gold xenon amp. just watching your gains and you'll be fine. not enough power is more likely to damage your speakers than too much power. what type of crossover are you going to use? if possible, run a bandpass signal to your mids instead of a low pass signal
Old Mar 8, 2010 | 11:17 AM
I think it will be fine. Many audio problems result from trying to get too much volume from speakers with a underpowered amplifier. The result is often clipping and distortion.
Too much power? No such thing. Just be reasonable with volume level.
Old Mar 8, 2010 | 11:19 AM
You read my mind while I was typing.
Old Mar 8, 2010 | 11:24 AM
blasian's Avatar
blasian
Are you going to be running 85 watts to the tweeter or to the mid?
davidc81's Avatar
davidc81
great audio minds think alike
Old Mar 8, 2010 | 11:48 AM
Chi-TownWarrior
Well I'm up in the air about going with the Audison Bit One, or the Zapco DSP6. I'm trying to keep the cost down, but both run around the same.
Well if the current tweeter goes, then oh well. I was planing on replacing it anyways. If I can avoid spending the money to replace it then good. I'm hoping moving it to the A-pillar will solve the harshness.
Well I plan on getting a 4 channel amp, so based off of the power these can handle. I want to ditch the amp I got now that does 85x2.
Thanks again everyone
Old Mar 8, 2010 | 11:57 AM
Chi-TownWarrior
Ok I wanted to touch up on this just bit.
I understand the different types of filters. Would I be wise to use a bandpass for all of the speakers?
Should I blend the frequency cutoffs or should I just set them to exactly to each speakers freq response?. I've alway questioned this one, but never asked and never found any info on this.
Old Mar 8, 2010 | 11:59 AM
blasian's Avatar
blasian
http://www.focal-america.com/extras/...wer/165KFx.pdf
Is that your mid?
I know the RMS on my components is the same power rating of my mids alone not including the tweeter. The RMS on my tweeters 50w RMS. Seems to be similar for most.
Is this your tweeter?
http://www.focal-america.com/extras/...wer/tn_52x.pdf
http://www.sonicelectronix.com/item_...l+165+KPS.html
I just found the tweeter model here but I wasn't really successful finding the mid.
Old Mar 8, 2010 | 12:07 PM
Chi-TownWarrior
Is that your mid?
Ok how the hell did you find this? That's everything. I suck at life . Thank you very much.
2 very stupid questions. Will running the tweets at 4ohm and the gains set properly hurt them or the amp, and when it say unfilterd, that just means that the RMS is higher if I run a filter for the tweets correct. I just want to check my info before I start.
Old Mar 8, 2010 | 12:08 PM
blasian's Avatar
blasian
lol on DLS's website it has the individual parts for the tweeter and woofer so I figured it was worth a shot to look to see if Focal did the same. Didn't find it there so I just looked at a place that sold them and then used those parts
Old Mar 8, 2010 | 01:24 PM
davidc81's Avatar
davidc81
you would run a bandpass signal to the mids and high pass on the tweeter. for my old active setup i ran my tweeters at 2khz and up and my mids bandpass from 60hz-2khz. i think i used a 24db or 18db slope.
how many amps are you running? if you have a separate sub and 4 channel amp, i could show you a way to get a bandpass signal just from the xovers in the amps so you wont have to spend anymore money. when i was active, i was using a phoenix gold ax-406a xover for a while and i've also run an active setup with an alpine cda-9833 headunit.
Old Mar 8, 2010 | 06:35 PM
Kwame's Avatar
Kwame
Wait for the JBL MS-8, I know I am.
Old Mar 8, 2010 | 06:46 PM
Chi-TownWarrior
I plan on running 2 amps 100x4 front 1200x1 sub. I think I know of what your talking about, but if you have a link or any info post please.
I've heard of it. Any idea of when it will come out?
Old Mar 9, 2010 | 03:55 AM
Kwame's Avatar
Kwame
...I've heard of it. Any idea of when it will come out?
There is an announcement expected real soon. My second choice would be the bitone.1 but I just would hate to buy the Audison piece now and the MS-8 end up coming to market right after.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
D_Rod
Sep 29, 2015 04:42 AM
