Alpine W900 installed
Old Mar 28, 2010 | 05:57 PM
Nismo#1554's Avatar
Nismo#1554
Default Alpine W900 installed
I got the new ALPINE W900 installed. With it I have bluetooth, backup camera, ipod, steering wheel controls and DVD bypass (allows me to play DVDs and use the navigation without being parked).
I'm disappointed with the cover art image. It looks really crappy and low resolution.
The DVD picture is a lot better than it looks in this picture. The vertical lines in the picture aren't visible at all in person.
You can move the guide cones a little to configure it but not really enough.
Next up is an Alpine 4.150 amp, Focal 165KR2s, and a JL W3.
Old Mar 29, 2010 | 03:40 AM
JMSpeed's Avatar
JMSpeed
Looks good. Did you install a switch for the bypass? What rear view camera did you use?
Oh, what dash kit is that?
Old Mar 29, 2010 | 08:47 AM
Nismo#1554's Avatar
Nismo#1554
Thanks.
The bypass is the PAC-TR7. It's always on and it made the install so much easier. You normally have to tap into the e-brake and foot brake, with the TR7 you don't have to worry about any of that.
The back up camera is the Alpine HCE-105 which works, but I learned that if you are going with the W900 you really want the HCE-107D back up camera.
The dash kit is American International. It looked great when I had the deck fully recessed but it didn't have enough clearance to open. I think it looks a little funky now.
Old Mar 29, 2010 | 06:12 PM
Spike100's Avatar
Spike100
Nice! Thanks for taking the effort posting pictures and the great screen shots.
Alpine’s visualization using guide cones is a very cool feature in the backup camera. The fact that you can adjust this makes it even better.
I understand your disappointment with the compromise on the flush fitment. But, I always prefer function over form, and it really does not look bad at all. Gaps are much worse than a slight protrusion.
I think one of Alpine’s best features is the sharp and clear LCD screens they incorporate into all of their devices.
Good installation.
--Spike
Old Mar 31, 2010 | 04:39 AM
JMSpeed's Avatar
JMSpeed
I plan on going with the Pioneer AVH-P4200DVD, so I'm not sure what I will do about the reverse camera.
That relay is perfect! My research only took me as far as the p-brake bypass switch but this is far more convenient. Thanks!
Also, I like the way the dash kit recedes a little allowing the head unit to be flush with the dash but also have room to open and close. Are the pictures posted how you currently have it oriented to function properly?
Your install looks very good. Thank you as well for pictures
Old Mar 31, 2010 | 08:45 AM
Nismo#1554's Avatar
Nismo#1554
Yeah, the pictures are of how it sits now. It works fine at that depth, it could even be pushed in a small amount more.
Old Apr 8, 2010 | 08:06 PM
T-Stan's Avatar
T-Stan
do you have any problems with the steering wheel connection, mine seems to only work when it wants to, the volume always works, but the seek "up" button only works sometimes.
Old Apr 20, 2010 | 10:12 AM
Nismo#1554's Avatar
Nismo#1554
Sorry for the late reply, I always forget to check in on these things.
My steering wheel controls don't work as quickly as they did with the stock headunit, but they get the job done. They all need to be held for a fraction of a second to work.
I found by skipping over the "seek up/down" part of the programing and only programing the button for "track up/down" it worked they way I wanted it to.
Old May 11, 2010 | 11:22 PM
6894kevin's Avatar
6894kevin
Looking to do this on my 07. I have bought the wheel controls, PAC-TR7, and will be getting the bluetooth, and rear camera soon. Im doing this for my first install, and need a little help if you could. Im also adding a 10 sub and an amp in the void behind the driver.
My question is where did you get the dash suround trim around the HU (exact sight), and where did you get the harness to install the headunit to the factory wires (sight)? I was going to wire the speakers to a seperate amp, but i'm not sure if im up for rewireing the doors and everything. Any help with the install would be great.
Kevin
Old May 12, 2010 | 01:13 AM
JoBAGZ's Avatar
JoBAGZ
How well does the navigation flow and work? Mini review?
Old May 15, 2010 | 04:55 AM
6894kevin's Avatar
6894kevin
Help!
Old May 16, 2010 | 05:59 AM
Dan Garcia's Avatar
Dan Garcia
Kevin
The double din dash installation kit combo you can get from E-bay, that's where I got mine and it came with the wiring harness. I got it from seller audiovideo4me for $19.99
dcains
Nov 11, 2015 11:36 PM
