is this amp enough?
Old Apr 8, 2010 | 06:46 AM
Saudi's Avatar
Saudi
Default is this amp enough?
so i decided on a set of 2 10" alpine type r's in a sealed box... not sure on front components yet, so any suggestions would be great... but i might have a great deal on an amp, but i know nothing of car audio....
JL Audio 500/1 Monoblock Amplifier
Specs:
500 Watts RMS @ 1.5-4 Ohms
Built-In Electronic Crossover, Selectable 12/24dB
24dB Subsonic Filter
Built-In Parametric EQ
THD: <.005% @ 4 ohms, 50Hz
S/N: >95dB at rated power
Frequency Response: 5 Hz - 200 Hz
Dampening Factor: >500@4 Ohms/50Hz
12dB Crossover
24dB Linkwitz-Riley Crossover selection (Any DJ knows what this is, Linkwitz Riley is known to be the most accurate type of crossover ever!)
Crossover Frequency: 40Hz - 200Hz
Subsonic Filter: 24dB
Subsonic Filter Frequency: 15Hz - 60Hz
Parametric EQ Frequency: 20Hz - 80Hz
Recommended Fuse Type: ANL
Phase Control
Requires 4 gauge wire kit
Dimensions: 13.4"L x 9.25"W x 2.36"H
thanx!!!
Old Apr 8, 2010 | 11:10 AM
Saudi's Avatar
Saudi
Looking for sound quality over loudness... I know they will be a little underpowered, but will it do the job for now?
Old Apr 8, 2010 | 11:36 AM
duro78's Avatar
duro78
first of all type r's arent really made for a sealed box there meant to hit hard and get loud so ported is really the only proper way to run an R. Your not giving enough info on the amp or sub. What voice coil config are the subs and what power is the amp putting out at the different ohm levels but ill tell you right now thats not enough power for two R's yeah maybe 1 but not 2 but till you get the right box it doesnt really matter also make sure you wire them properly and check the config. What are you getting the amp for? If ists really cheap get it and sell it. But I promise you 1 of those 10's in a properly tuned box will get louder and hit harder than the 2 in a sealed
Old Apr 8, 2010 | 01:18 PM
Nismo1534's Avatar
Nismo1534
I had two 12in Alpine Type-R's in a sealed box and loved it. Very sharp, tight bass. Sure, it's not going to be this loud, thunderous bass that you can hear blocks away, but way more than enough in a hatch.
Old Apr 8, 2010 | 01:49 PM
davidc81's Avatar
davidc81
it should be good enough but i would go with a 1000/1
Old Apr 9, 2010 | 03:20 AM
duro78's Avatar
duro78
type r and what you described dont go together. r's and sq=nope
duro78's Avatar
duro78
op type rs arent for sq
Old Apr 9, 2010 | 08:22 PM
Saudi's Avatar
Saudi
when i listened to two type e's, and one type r, the sound difference to me was a tighter cleaner sound...
so if sq is what i am after, suggestions?
Old Apr 10, 2010 | 04:26 AM
duro78's Avatar
duro78
Check out image dynamics or diamond audio.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
