Where did you mount your gps antenna?
Old May 4, 2010 | 07:16 AM
mpthree50's Avatar
mpthree50
Default Where did you mount your gps antenna?
Hey, I am planning on installing a pioneer avic X910BT in my Z, just curious where everyone is mounting the gps antenna. Pics would be great also, thanks!
Old May 4, 2010 | 08:01 AM
Waiz's Avatar
Waiz
https://my350z.com/forum/audio-and-v...s-antenna.html
Old May 4, 2010 | 10:11 AM
mpthree50's Avatar
mpthree50
Thank you, didn't see this in the search I did this morning.
Old May 4, 2010 | 07:23 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Dead nutz center of the dash. Under the plastic works too.
Old May 5, 2010 | 05:11 PM
Spike100's Avatar
Spike100
^^ Yes…
I think people worry too much about the mounting position for the GPS antenna/receiver. That is probably because the manufacturer recommends in the installations instructions that you mount the GPS antenna/receiver outside the car (they usually recommend a roof mount). That is overkill. In fact you can mount the GPS antenna/receiver inside the car, and even under plastic panels, and expect good results
I have my GPS antenna/receiver on the rear strut bar in the Z coupe, and it works perfectly. Placement in the upper/forward cubby works as well (I mounted a Garmin here, and reception was not a problem).
About the only way to defeat GPS reception is mounting the antenna/receiver where it is” blocked by/shrouded in” sheet metal.
--Spike
Old May 8, 2010 | 08:48 AM
jonny_q's Avatar
jonny_q
i mounted mine for my pioneer vehicle dynamic processor in my passenger a pillar beside my factory gps antenna. it has worked very well for me. the pannel had enough room to easily fit and there was a large enough flat spot for the magnet to grab onto. when i do an alarm starter i may also hide that antenna there for a nice clean stealthy install
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
