Dynamat Xtreme vs Dynamat Superlite
Old Jun 8, 2010 | 04:31 PM
SekZee's Avatar
SekZee
Default Dynamat Xtreme vs Dynamat Superlite
Is dynamat superlite worth it?
Xtreme is 0.45 lbs per square foot, but I can't find anything about Superlite, it says it's 20% lower..
Which one should I go with?
Old Jun 8, 2010 | 05:26 PM
Rubidium's Avatar
Rubidium
The selling point is you can do an entire sedan, the whole damn floor, doors ceiling, and trunk and only gain 30lbs. Superlite is a bit more expensive when I've found it. I like buying off amazon.com, got a bulk pack of Xtreme for $134.00 (50% off retail). I'd go with superlite as long as you're not putting some extremely heavy (and hard hitting) subs in there.
Old Jun 8, 2010 | 11:24 PM
orgasm_donor's Avatar
orgasm_donor
There is really no replacement for mass (weight). I found the Hushmat poly-based product to be cheaper than DX and still be of exceptional quality. I have 108 square feet of in in my Z and its incredible.
Old Jun 9, 2010 | 07:53 PM
Spike100's Avatar
Spike100
Here is my understanding of Dynamat Xtreme vs. Dynamat Superlite. Hopefully someone will correct me if my statements are not correct.
  • Dynamat Xtreme is thicker, heavier, and provides the best sound-deadening.
  • Dynamat Superlite is more thin (i.e., easier to install), lighter, but provides slightly less sound deadening. This product depends upon sealing the sheets end-to-end or at the sheet’s terminus to get the best result.
Notice that the Corvette has very thin sound-proofing panels, but the panels are fit precisely and deaden very well. That is the concept for the Dynamat Superlite (lighter, thinner, and better fitment to achieve sound deadening with a lighter weight product).
--Spike
Old Jul 7, 2010 | 08:14 AM
Iceman007's Avatar
Iceman007
How much does it cost to dynamat just the rear hatch area?
Old Jul 7, 2010 | 07:03 PM
orgasm_donor
anywhere from $50 to $200 depending on how many layers and the quality of materials.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
PureR3d
Sep 10, 2015 06:23 PM
