X920BT Install - Ack Speedometer not working
Old Aug 13, 2010 | 05:14 AM
SHIFTcanadian's Avatar
SHIFTcanadian
Default X920BT Install - Ack Speedometer not working
So I installed my X920BT last night. Turned car on, everything is great.....except....
My freaking speedometer and trip mileage doesnt work now. Also my turn signal lights work on the outside, but dont blink on the inside.
Is that all related to the VSS wire? Or did I screw something else up?
Old Aug 16, 2010 | 08:07 PM
idkorcare's Avatar
idkorcare
If I was in your position I would unplug the radio you just installed and make sure you plugged everything else back up(hazard switch, gauges above radio) and possibly try letting the car reset if all that fails by disconnecting the battery for 10-20 mins.
I have pretty much the same radio in my wifes car and after looking at where the VSS is I have a feeling I didnt hook it up and it works fine. So if that is your problem just leave it off.
416blueZ
Jun 11, 2024 10:56 AM
m_0g
Jun 3, 2021 10:05 AM
davidm350
Oct 31, 2015 02:28 PM
416blueZ
Sep 24, 2015 02:11 PM
Shane86
Sep 17, 2015 05:33 PM
