Need help!! cigarette outlet doesnt work...
Old Aug 18, 2010 | 06:31 PM
Trunks51's Avatar
Trunks51
Default Need help!! cigarette outlet doesnt work...
so i was using a air pump thing (connects to the cigarette outlet) trying to pump my tires today, it was working fine for the first one, then when i got to my second tire, it stopped working and so did the other outlet which has a radar detector connected to it... does that mean i burned the fuse? and if so, how can i check? cuz both of them stopped working... thanks!!!
Old Aug 18, 2010 | 08:25 PM
sdZ33's Avatar
sdZ33
Check the fuse at the driver side kick panel
Old Aug 18, 2010 | 08:29 PM
Spike100's Avatar
Spike100
Most likely you did blow a fuse. Air compressors draw significant current. When I run off-road with my 4WD and use this type of device to air-up after deflating for better traction, I use a a dedicated power line.
Your Z's Owner's Manual shows the fuse box.
--Spike
Old Aug 19, 2010 | 03:56 AM
djarno's Avatar
djarno
Z
Same thing happened to me a while ago. Replaced the fuse and everything was back to normal.
Old Aug 20, 2010 | 06:57 AM
Trunks51's Avatar
Trunks51
yeah i replaced the fuse and everything's fine now... thanks!!
NFAC
Sep 26, 2015 10:11 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
FastEddie73
Mar 2, 2003 08:02 AM
FastEddie73
Mar 1, 2003 05:56 AM
stevelee2001
Sep 12, 2002 05:56 AM
