Rear Speakers - Aftermarket Replacement Scratchy Sound
So, I've searched the forum and there are some awesome DIY on the rear speaker replacement but I can't seem to find the answers to the following questions.
In the 2005 Z, for the rear speakers, if I am using the stock wiring, which one is positive and which one is negative? I don't have a volt meter and I was wondering if anyone could help.
Also, when I install the speakers (Polk DB651s) regardless of how I wiring the speakers, the sound is scratchy, any one know the reason?
Should I just buy and OEM replacement speaker or can I actually get these Polk speakers to work on the stock system? I've upgraded the stereo, so they should be getting plenty of power. My car is in pieces now
I can't say that I connected them properly, because I couldn't figure out which one is a positive and which one is the negative. I assume that if someone can tell me that, then I can get a better connection.
I agree that it's not a good idea to use the stock speaker wire, but I didn't want to add to the hassle of replacing the back speakers and I went for something that was just a little better than OEM.
So, I guess the big question.......
At the actual speakers in the rear of the car, where they plug in to the OEM speakers, which wire is a positive and which is a negative?
Chances are tonight I will just buy a volt meter and test this myself, but I really thought this information would be easier to find, but it definitely isn't.....and I am pretty good at using Google
remove factory speaker , cut off factory plug where - & + speaker wire terminate at the plug leave 2 " of speaker wire attached to the plug , strip a tab bit of speaker wire off of the 2" you left , take a 9 volt battery touch the speaker wires to the 9 volt , if the speaker moves in your wiring as it touches the 9 volt is backward, if the speaker moves out than the wiring is touching the battery correct
when speaker moves out note what color wires are touching - & + terminal of 9 volt as you have it correct when speaker moves out
Thanks for all the help, I read about the 9V battery trick, but I never thought about using the stock speaker with the wires attached to find this out. That's pretty clever. Also, with the magnet touching the edge, could be the issue.
I appreciate all the solid help.
Thanks
Thanks
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
seagrasser
Oct 11, 2015 03:27 PM
