Radar Detectors
Old Nov 28, 2003 | 06:00 PM
Rushkiboy's Avatar
Rushkiboy
Default Radar Detectors
How does everyone have there radar detectors hooked up if the outlet is in the back. Don't know if you can buy longer cords, say at Radio Shack. Even trying to hard wire it to the fuse panel you would need a longer cord.Thanks
Old Nov 28, 2003 | 06:21 PM
MIKE3348's Avatar
MIKE3348
Default radar detectors
I made a mount that mounts my escort 8500 to the rearview mirror. I used the optional hardwire cord with mute botton from escort to wire mine to the fusebox. I mounted the mute button low on the dash. Enclosed are a few pic's.
I have sold a number of mounts to other forum members. pm me if interested.
Old Nov 28, 2003 | 06:22 PM
MIKE3348's Avatar
MIKE3348
pic2
Old Nov 28, 2003 | 06:23 PM
MIKE3348's Avatar
MIKE3348
pic 3
Old Nov 29, 2003 | 12:52 AM
iChiBahN's Avatar
iChiBahN
isn't valentine or something better than escort?
Old Nov 29, 2003 | 04:11 AM
hwj's Avatar
hwj
Use the curly cord that originally came with your Escort or Valentine1, buy a 4 wire telephone line Coupler and a 6 foot telephone line.
Plug them all together since you're just making an extension cord of sorts; leave the coupler under the passenger seat and tuck the straight phone line wire under the center consol; leaving enough extra line hanging out of the front of the consol to reach to the window mounted detector you're using. If you buy a white coupler it's easy to see when you need to disconnect; buy a black line and you'll barely notice it as it blends into the interior's color.
I've spent the extra money on the Valantine1 [V1], got a ticket with the Escort due to it's poor K band reception. The V1 just blows away the Escort in picking up the Pa. State Police's radar traps here. I liked its performance so much I purchased another for my daily driver as well, and don't have to constantly switch it out of one car to the other. My Escort now collects dust in the box.
Old Nov 29, 2003 | 09:28 AM
TZUNAMI's Avatar
TZUNAMI
Hey Mike 3348, do you make that bracket so it would fit the Valentine 1? I really like the way it looks, BTW.
Old Nov 29, 2003 | 09:47 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Mike: Nice job on the bracket! I like it.
As far as hard wiring the Valentine One, you don't need to buy any more cord. I just used the hardwire cord that comes with the unit and cut off the coupler on the end and wired to the cig. lighter fuse.
Old Nov 29, 2003 | 11:36 AM
mrsnetpro's Avatar
mrsnetpro
I had the cord installed into the wiring at the top so that I just plug it in and it sits on the visor. I was told that if it was mounted and sat on the dashboard anybody I pass would notice it easier and if they were directly behind me (under a car length) there was a chance they could block any radar hits from behind. Nobody who has passed me (when I moved over because the radar went off) noticed it, but if the person in front of me had it on their dash they did and THEN slowed down.
Only thing about the detector is it is fond of the overpasses on most of the highways in North Carolina....even when there isn't a thing visible for miles... (I live in New Jersey and visited there a few weeks ago)
Stacy
Old Nov 29, 2003 | 12:02 PM
12yearZ's Avatar
12yearZ
(I don't know much about radar detectors) but is there a radar detector that can be run through a carputer or something, so there is no visible unit at all, except maybe a small, nodescript receiver?
Old Nov 29, 2003 | 03:21 PM
maximadave's Avatar
maximadave
Mike you have a PM
Old Nov 29, 2003 | 05:38 PM
350Z-RED's Avatar
350Z-RED
i got the Escort Solo2, which is wire less (runs on batteries)
works great
Old Nov 29, 2003 | 08:04 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Gotta be careful with the battery powered ones though. They aren't as accurate as the corded ones. You lose detection power as the batteries drain.
12yearZ: They make completely "stealth" detectors that mount in the grill up front. Only the signal lights are inside the car.
Old Nov 29, 2003 | 08:53 PM
SungNamZ's Avatar
SungNamZ
works great
I have the Escort Solo2 w/Mike's mount. It is a GREAT mount! The unit gives a battery low warning with sufficient power to replace batteries. Just must insure you have extra batteries onhand. Zaino reduces battery drain.
Old Nov 29, 2003 | 09:05 PM
MacGyver's Avatar
MacGyver
Not only that, but they cycle power to save on battery life. You're only actually detecting anything about 20% of the time...they usually cycle around 1 second on to 4 seconds off. May not seem like much, but tell that to the officer as he writes you the ticket. If he targets you just after the detector cycles down, the officer has a good 4 second lock on you before you know he's ahead.
Old Nov 30, 2003 | 11:46 AM
NTRIGUE's Avatar
NTRIGUE
Default K40 Detector/Jammer
This detector is built into front/rear plate frames and has a red LED that install in the gauge cluster.
$1200 installed!!!
Old Dec 1, 2003 | 05:27 AM
350Z-RED's Avatar
350Z-RED
I set mine to always on, so more or less removed the battery saver option, i always have a spare of AA's on hand
thanks
Old Dec 1, 2003 | 02:39 PM
12yearZ's Avatar
12yearZ
Are the fully stealth (built ins) better than say the V1? Also, are radar detectors illegal (I'm in california).
Old Dec 1, 2003 | 04:03 PM
MacGyver's Avatar
MacGyver
Using detectors in Virginia is illegal, even owning one in D.C. is illegal, legal in all other states.
Old Dec 1, 2003 | 09:35 PM
NTRIGUE's Avatar
NTRIGUE
Still legal in Cali.
