Subwoofer Amp or Subwoofer?
Old May 24, 2011 | 01:13 PM
Jimmyg41's Avatar
Jimmyg41
Default Subwoofer Amp or Subwoofer?
I have a Bose system in my Z (3rd car with bose...3rd car with audio system problems). I pretty much suck with all that is car audio. My sub keeps cutting in and out. When it's in it sounds good and normal. Usually a tap to the enclosure where the stock sub is will temporarily bring the sub back to life. Is this more than likely a sub amp problem or is there a possibility of loose wiring? I doubt it's the actually subwoofer but who knows. Any suggestions or ideas?
Old May 24, 2011 | 04:24 PM
Ediblesky's Avatar
Ediblesky
It's the relay inside the amp. I have the same problem. View this for a cheap temporary fix.
https://my350z.com/forum/audio-and-v...-drop-out.html
Old May 26, 2011 | 10:24 AM
Jimmyg41's Avatar
Jimmyg41
Thank you! I'm going to try it this weekend. You might have saved me $70!
Old May 26, 2011 | 04:58 PM
Spike100's Avatar
Spike100
The problem you report is a wiring/connection problem. Trace the physical wires and you will discover the problem.
--Spike
Old May 28, 2011 | 10:07 PM
Jimmyg41's Avatar
Jimmyg41
I will check for both loose wiring and the subwoofer amp since I'll be in there. Thanks for the info.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
