after stereo install abs/slip warning lights stuck on.
Old May 25, 2011 | 01:35 PM
darkkstar's Avatar
darkkstar
Default after stereo install abs/slip warning lights stuck on.
i did stereo install. after putting everything back together, my gas gauge doesnt work, the abs/brake warning light is stuck on, also the tcs/slip light is stuck on and my heater air conditioning console doesnt work. i double checked to make sure heater/ air cond is plugged in.
Old May 25, 2011 | 01:41 PM
Spider Monkey's Avatar
Spider Monkey
Hey bro,
You fucked shit up.
Old May 25, 2011 | 02:17 PM
350ZTheStandard's Avatar
350ZTheStandard
Bummer, I had the problem with the ABS & TCS & had to have the stealership reset my car. Try to disconnect the battery for 10 mins or so, or get a hold of a code reader to clear the codes. Good ruck feLLa.
Old May 25, 2011 | 04:19 PM
darkkstar's Avatar
darkkstar
please remove this tread. it was a loose connector.
Old May 25, 2011 | 04:41 PM
DavesZ#3's Avatar
DavesZ#3
It's a pretty common mistake. Either forgetting to plug up the connector that goes to the gauge or the one that goes to the A/C control unit.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
07ZEKE
Aug 23, 2021 09:15 PM
samansharif
Sep 25, 2015 12:31 PM
