Universal Parking Brake Bypass $1
Old May 27, 2011 | 10:42 AM
dragonfire6's Avatar
dragonfire6
Default Universal Parking Brake Bypass $1
Got a new Z and had to reinstall my system. I have the Pioneer AVH-P3100DVD and this unit makes you go the extra mile before you can watch a movie while in motion (you can't just ground the Parking Brake Wire)... There is a relay fix for this but I had been using a toggle switch to trick the unit. For my reinstall, I purchased a Momentary Off Switch (On-Off-On) on eBay for $1 and grounded one terminal and connected the other to the Parking Brake Wire on the unit. I mounted the switch below and to the right of the steering wheel.
This is a pretty clean, universal fix for any DVD player. The momentary switch provides a constant ground and when pressed will block the ground connection momentarily to trick the unit. Thought I would post this up as a cheap alternative for everyone...
Old May 27, 2011 | 11:28 AM
bmccann101's Avatar
bmccann101
this sounds like heresy..
ALCHEMIST!
Burn him!
jk.
Old May 27, 2011 | 11:32 AM
350zspl's Avatar
350zspl
slow down on the oxy
Old May 27, 2011 | 11:34 AM
bmccann101's Avatar
bmccann101
were out of files at work... waaaaaay bored, it happens.
Old May 27, 2011 | 11:42 AM
flecko28's Avatar
flecko28
did you not use the relay method because you already had a hole drilled for a switch?
Old May 27, 2011 | 12:21 PM
NZMOWND's Avatar
NZMOWND
yeah the relay is much cleaner and requires me to do NOTHING to watch a video...laziness FTW
samansharif
Sep 25, 2015 12:31 PM
