Speakers make high pitch noise then pop
Old Jun 14, 2011 | 09:11 PM
HeLLSaTaN's Avatar
HeLLSaTaN
Default Speakers make high pitch noise then pop
Stereo setup:
Avic 710BT
JL 300/4 amp
4 alpine speakers at 75w each [dont remember the model]
I've had my stereo installed and working just fine for about a year now and zero issues until recently. My speakers on startup sometimes (not on every startup) make a very high pitch noise and then within about 10-20 secs they will pop and then be fine. Only happens once and then everything is normal.
Wire loose? bad ground? I just wanna hear some thoughts before I go rip my whole interior out and find out and not forget anything.
Edit:
My ground is hooked up to my passenger seat.
I think i might of found my answer. I didn't setup my rears with the crossovers that were supplied and the rears are trying to play highs when they cant.
Old Jun 15, 2011 | 12:14 AM
OkashiZ's Avatar
OkashiZ
it sounds like a bad ground somewhere, or a fuse issue. if it is ground to your passenger seat, did you first take the black paint off of the metal? that could be an issue.
Old Jun 15, 2011 | 07:03 AM
350zspl's Avatar
350zspl
either your pioneers pico fuse is taking a crap
or bad ground
Old Jun 16, 2011 | 04:04 PM
HeLLSaTaN's Avatar
HeLLSaTaN
ill check the grounds this weekend when i get free time. thanks
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
samansharif
Sep 25, 2015 12:31 PM
